Photos of the Week:
Avalon Theatre
Avalon Theatre-1 2 3 4
1 members (Admin), 117 guests, and 33 robots.
#179850 08/03/08 11:47 AM
Admin Online Content OP
The first pic shows a piece of 3/4 rigid. If you look closely you'll see a white wire on one end that I was trying to get out of the pipe. I wanted to use the pipe again so I sawed it off right in the middle of a coupling. Imagine my surprise when I still couldn't pull it out. The 2nd picture shows why, ice had pushed the neutral wire thru the crack in the pipe. No one ever noticed it as you can see by the paint on the wire. I think its quite likely the conduit was carrying the current for the device the neutral was hooked to. It happened to be a 2" solenoid valve on a gas tank. oops
Jon aka Walrus
[Linked Image from electrical-photos.com]
Admin #179863 08/03/08 06:01 PM
This just goes to show that no matter how much I do, there is always something new to see. Glad no one got hurt with this. Probably no way to tell how long it was like that.
GA76JW #179868 08/03/08 11:48 PM
You do understand that if you were trying to make this happen, it would have never occurred, correct?
---Ed---
This is the 2nd time I've seen this. The other time it was a hot conductor so it tripped the breaker. Water in conduit above grade makes for busted pipes in the north country. Seems odd it would push a wire out the side like that
walrus #179898 08/05/08 07:27 AM
We chased an intermittent short caused by this same thing a number of years ago. When the water froze there was no short and when the ice melted the pipe made contact with the wire and caused the fuse to blow.
At my home I ran conduit for my phone out to the pole using rigid risers and nineties and PVC between the house and the pole. The second winter the water froze in the 90 at the house and actually pulled the phone cable apart. The cable was the standard 3 pair underground cable with the gopher shield and it was completely separated by the action of the ice. I ran temp over the ground for the rest of the winter and when I replaced the cable in the spring, I drilled holes in the conduit to allow the water to drain and have not had a problem since.
I have also had the fibers of a fiber optic cable crushed and broke by the action of ice in rigid conduit.
I made a proposal a number of cycles ago to require that rigid conduit and concrete encased conduit be installed below the frost line for underground installations to prevent problems like this but it was rejected.
Tools for Electricians
2023 NEC + Exam Prep Study Guides Now Available!
HappyElectrician
HappyElectrician
Penn USA
BigB 2
353,430 Are you busy
277,256 Re: Forum
256,260 Need opinion
