205
28
I've noticed on small commercial buildings that residential cans are installed. Instead of romex, MC cable is run. Recently I changed some bulbs on a job and wrote down the model of the can: http://www.junolighting.com/product_detail.asp?ino=2171&Sel_Id=1706&brand=1Is it okay to install a residential can and what is the difference? Is it mostly up to the architect? Thanks, Byron
Posts: 7,381 Likes: 7
Why are you saying 'resi can'??
Other than 110.3(B), the code does not distinguish between "residential" and "commercial" products. This is likely a design consideration only.
Bryan P. Holland, ECO. Secretary - IAEI Florida Chapter
Yeah I don't see what the difference would be a lot of building owners by cans like that because of the cost you can by them cheap at the ORANGE apron place.
The OP is in CA.; perhaps a State thing??
Not a CA thing at all. Look at all the different grades of wiring devices. There's residential grade, commercial grade, specifications grade, etc.
Nothing says you can't use specification grade devices in a residence, or "cheapy" residential grade devices in an industrial building. It's a design issue.
The same applies here, to the lighting package.
As electure stated, I've never heard of any regulation, even on the county or city level, making a distinction between these products.
Traditionally, you would use a more robust product in a commercial environment due to long hours of operation, harsher environments, etc. On the other hand, residential usually denotes a stricter budget. These are design and $$ considerations, not parameters designated by any orginization or AHJ that I'm aware of.
Posts: 9,928 Likes: 34
Other than the fact that commercial renovations are generally 100% tax deductible I never understood why you would use a more expensive luminaire in a commercial setting like a strip mall. In a residence people are more likely to actually look at it and most of these strip malls get gutted and rebuilt every 4 or 5 years around here. I am sure most of the space they are building right now will not last 5 years. This looks like the 80s to me where we built several million square feet of commercial in a couple years and never actually rented more than 75% of it.
