ShoutChat Box
Tinfoil-hat crowd is getting stupider...
by Trumpy - 05/30/20 08:45 PM
2020 GFCI changes
by gfretwell - 05/30/20 03:20 PM
Norwegian power?
by WaterIngress - 05/27/20 11:43 AM
Tips on how to read 2018 CE Code Book?
by Rob2019 - 05/23/20 10:02 AM
Pool Lights?
by gfretwell - 05/21/20 02:03 PM
Facebook follies, bad wiring
FPE in Germany pt.2
1 registered members (Scott35), 77 guests, and 9 spiders.
Wind generator failure #175470 03/02/08 12:06 PM
Active 1 Offline OP
Re: Wind generator failure [Re: Active 1] #175471 03/02/08 12:10 PM
leland Offline
Now that could hurt a boater!
No wonder My senior Senator does'nt want them offshore of his compound!:)
Re: Wind generator failure [Re: leland] #175472 03/02/08 12:28 PM
JoeTestingEngr Offline
Seeing something like that would probably drive him to drinking. Nevermind!
Joe
Re: Wind generator failure [Re: JoeTestingEngr] #175473 03/02/08 12:45 PM
JValdes Offline
You think with all the technology, someone would have tought about this happening. It's called a brake!
There are so many ways that windmill could have been fitted to spin only so fast.
ps...centrifical clutch come to mind.
Re: Wind generator failure [Re: JValdes] #175474 03/02/08 01:46 PM
SP4RX Offline
In this case the mechanism that limits the speed of the windmill is called a "break"!
Re: Wind generator failure [Re: SP4RX] #175475 03/02/08 02:16 PM
sparkyinak Offline
It broke alright! smile
Re: Wind generator failure [Re: SP4RX] #175476 03/02/08 02:16 PM
resqcapt19 Offline
I don't think that they use breaks. I believe that they change the pitch of the blades to limit the speed.
Re: Wind generator failure [Re: resqcapt19] #175479 03/02/08 02:52 PM
gfretwell Offline
The ones I looked on out Dakota trip last summer (Minot ND) only pitch the last few feet of the blade tip but I saw it bring one down to a dead stop in a minute in a a fairly good wind. Still not sure why they feathered it since the twin next to it was still going. My thought was it was easier to do load leveling with this than coal/synfuel fired plant down the road in Beulah.
Re: Wind generator failure [Re: gfretwell] #175481 03/02/08 03:05 PM
gfretwell Offline
This is a link to a picture I took showing the tips being feathered
http://esteroriverheights.com/electrical/wind_turbine_minot_nd.jpg
Re: Wind generator failure [Re: gfretwell] #175501 03/03/08 07:54 AM
SteveFehr Offline
When I saw this topic, I thought you meant the wind generator failure in texas over the weekend, where the wind in the panhandle suddenly dropped and texas nearly went into rolling blackouts. They were saved by... (drumroll, please) thousands of small diesel generators! Which fired up at industrial sites across the state and took up the delta from the 4% of the state electric load the wind turbines normally provide.
I look forward to seeing 20% of our energy provided by wind and solar...
2020 National Electrical Code
Code (NEC)
2017 Master Electrician Exam Preparation Combos
2017 NEC Electrician
Exam Prep Combos:
Master / Journeyman
watersparkfalls
watersparkfalls
Washington...Not DC
Show All Member Profiles
Trumpy 8
266,149 Are you busy
200,990 Re: Forum
189,677 Need opinion
Powered by UBB.threads™ PHP Forum Software 7.7.3
