Violation?
by renosteinke - 01/27/23 09:52 PM
Does NEC 551.71 (F) apply to dwellings?
by BigB - 01/20/23 10:46 AM
Power submeter connections
by HotLine1 - 01/19/23 09:09 AM
AFDD's coming to the UK
by Texas_Ranger - 01/17/23 07:22 PM
Burger King crown sillyness
by wa2ise, December 11
240/208 to a house
240/208 to a house
by wa2ise, October 9
0 members (), 28 guests, and 14 robots.
Which way do you think is the best way to mount ground flood lights ( 150 wt. HPS ) ( 100 HPS ). I imagine I'll run uf cable to these fixtures, mount fixtures to a wp box with wp cover, using the 1/2" nipple off the fixture to screw into the cover. Use 1/2" rigid galvanized pipe to support the box, and flex out of the ground with wp flex into the box. Any other ideas?? Thanks, Steve..
Since you're using UF....how about a 'rocket-perma-post'?
Manufactured PVC tube with stabilizing fins, 1/2" NPT on top. (Arlington?)
Eliminates WP box, cover, flex, etc.
Redsy:
Thanks for the link......
John, thanks for the idea. Yep, that's the way I want to go. Looks better too. Thanks again. Steve..
Z
Try looking into the RAB "mighty-post". All PVC, so the inevitable replacement of the fixture will not include replacement of a rusted-on post cap.
I've tried the other brands of these perma-posts, and RAB makes the best.
Good Luck!
Tools for Electricians
2023 NEC Now Available!
2020 Master Electrician Exam Preparation Combos
2020 NEC Electrician
Exam Prep Combos:
Master / Journeyman
BigB 8
triple 3
302,629 Are you busy
231,937 Re: Forum
216,584 Need opinion
