1 members (Scott35), 529 guests, and 21 robots.
#17263 11/23/02 08:11 AM
Sandro Offline OP
My local supplier has a huge C-H advertisement photo for arcfault devices, just like the pictures you see in the website (www.arcfault.com). C-H clearly shows a 2-pole AFCI breaker. My problem, me and my men have been wiring residential with 3-wire feeds and now, I hear that 2-pole AFCIs are not available. Whats with this??? Are 2p only available in US? If so, why not in Canada? The C-H rep has yet to call me back.
Is there any way I can wire two single pole AFCIs to work with my 3wire feed set up?
Cheers!
I don't beleive it is possible.
There is a good thread going on this topic, on the Mike Holt board.
I know tha AFCIs from Square D do not work with a shared neutral.
Here is that info I posted at MHE regarding the AFCI breaker manufactured by Cutler-Hammer that is meant for use on Multiwire circuits:
Following quote is from FPN notes pertaining to CJH215AF, CJH215GFAF, CJH220AF, CJH220GFAF 2 pole AFCI Breakers on the bottom of page 3 in th ePDF File linked below.
2-Pole AFCI breakers are designed for use in 3-wire, 120/240V AC circuits, 120V AC multiwire circuits utilizing a shared neutral (often referred to as a “home run” circuit), and 240V AC circuits obtained from 120/240V AC source.
https://www.ch.cutler-hammer.com/docs/Fred/apscpgh/htmL/550000/F5.PDF
If the proposal to require all of the circuits to be AFCI protected on a Service Change is accepted,all manufacturers will have to start making them for the millions of homes with multi-wire circuits.
manufacturers see $$$$$, homeowners say...they cant afford upgrade
Donnie
i forget what 'AFCI' thread it was a while back..... i had systematically e-mailed the tec supports of a number of common manufacturer's.
Most claimed a 2-pole AFCI would be available fall 02' to spring 03'....
