0 members (), 201 guests, and 38 robots.
Whats a good priced voltage performance monitor, line recorder, power quality data logger, etc.
I need just a simple one, as inexpensive as possible. If you know the estimated price that would be great too. Thanks.
Probably will only get used once in a blue moon.
** From looking real quickly this is what I have found at about $500.
http://www.idealindustries.com/prod...y_meters/voltage_performance_monitor.jsp
I'm not sure if thats what I need. I would like to log the service of a medium size office.
Shake n Bake
Trick:
I use(d) the Amprobe Digimatic....Voltage, amperage, time.
No printout, all digital with battery b/u.
Unit has CT's and voltage clip-ons, and requires 120 volt power to plug-in.
I still have it. Send me a PM or e-mail if you are interested.
K
Trick440,
From what I can gather from the downloaded instruction manual, it looks like that Ideal unit may only be good for single phase, maybe even only an individual branch circuit. I think you would need to be able to monitor all phases at once to get an accurate account of what is happening in a commercial setting.
I have been looking around for a new PQ meter myself and so far, the one that offers the most features and bang for the buck is the Extech 382090.
At $1995.00 it is full featured, can log up to 20,000 readings, shows PF and 1-27 harmonics. It also comes complete with four current clamps for true 3-phase monitoring, a set of standard alligator test leads, carrying case, batteries and software for downloading data to your computer. The software is an important item, because you really have to be able to print out and show the test results to the customer. Especially if you are going to make recommendations for expensive changes to be made.
All the new Fluke units I have looked at are well over $4000.00. That is just too much for a small company to purchase just for occasional use. I think this may be why many electrical contractors leave this type of work to others who specialize in the PQ field. smile
Regards
cookcc
cookcc
California ,Long Beach
Trumpy 5
dsk 1
davey 1
552,972 Are you busy
427,593 Re: Forum
398,061 Need opinion
