ShoutChat Box
Questioning the electrical norms
by gfretwell - 07/09/20 04:35 PM
Ceiling Fan Capacitor Question
by markmc00 - 07/08/20 01:39 PM
Blo breaker
by Admin - 07/07/20 02:42 PM
"Electric furnaces" and other odd American heaters
by gfretwell - 07/05/20 12:37 PM
PC has killed Experimentation?
by LongRunner - 07/04/20 02:37 PM
Facebook follies, bad wiring
FPE in Germany pt.2
1 registered members (Scott35), 15 guests, and 11 spiders.
Sharpen Unibits? #169539 10/07/07 10:50 PM
PE&Master Offline OP
Anybody have a method for sharpening a unibit? I have several that have dulled and need an edge but not sure what the best method is to do it.
Is there a sharpener available?
Re: Sharpen Unibits? [Re: PE&Master] #169543 10/07/07 11:16 PM
renosteinke Offline
A tool sharpening house would be the best bet. They won't be able to restore the coating, but they can renew the point. Otherwise, they can dress the flat edges, as they would do with a countersink.
Re: Sharpen Unibits? [Re: renosteinke] #169556 10/08/07 08:04 AM
gibbonsseabee80 Offline
My Unibits last a long time by buying a couple of 1/4" metal drill bits. I make a pilot with a 1/4" drill bit and then drill with the unibit. I also use a small drill bit when trying to make bigger holes in metal with bigger drill bits. This saves the point. By the time they go bad, I usually just toss them. They are very expensive but I got the most out of them by using my method. I dont have any suggestions for sharpening.
Brian Gibbons
Re: Sharpen Unibits? [Re: gibbonsseabee80] #169574 10/08/07 10:48 PM
michaelpwalton1 Offline
I usually sharpen them on a grinding wheel... You have to get the relief correct or the bit will walk while trying to start a hole. I compare the bit that I am sharpening with a known good bit.
I admit that it is some what hit or miss, but I figure that the bit is not working right, so I have nothing to loose.
Re: Sharpen Unibits? [Re: michaelpwalton1] #169577 10/09/07 12:33 AM
gfretwell Offline
Sounds like something a dremel would work for.
Re: Sharpen Unibits? [Re: gfretwell] #169588 10/09/07 12:50 PM
macmikeman Offline
There is a way to make them last longer. Try using one of these type services to increase the life of any metal bits. Diversified Cyronegenics Click the tab cyrogenics 101 to see how.
Re: Sharpen Unibits? [Re: macmikeman] #169611 10/09/07 08:27 PM
SP4RX Offline
This idea occurred to me several months ago too. So I brought home my near-the-end-of-it's-life-cycle-unibit and fired up the old dremel. I did the best I could to keep the edges straight, but without some sort of a guide it's quite hard to do. Also where the bit steps to a larger diameter it's difficult to sharpen the edges while maintaining the proper angle of the step...difficult to describe...difficulter to do. All in all it was not an easy task. The results speak for themselves: The bit now works fantastically well! (for making holes in drywall.) And it was nice to finally use a sharp unibit...when I picked up a replacement.
I was doing some work in a machine shop so I asked if they would be able to sharpen a unibit for me. Apparently it would take about 2 hours to do and it would cost more than a new bit.
I agree with Gibbons and make a pilot hole first and then switch to the unibit. It prolongs the life of the tip at least.
I also have a plastic case from a short auger bit, about 3" or 4" long that I store my unibit inside. Then the bit's cutting edges aren't bouncing around hitting stuff and being dulled in my tool box.
Shawn.
Re: Sharpen Unibits? [Re: SP4RX] #170872 11/13/07 10:59 PM
Ok I was reading electrical contractor magazine and found an interesting product. Finally someone came up with nice solution to an expensive problem. Let me know what you think and if anyone is going to try them. Brian
http://www.ray-tools.com/tipbits.htm
Brian Gibbons
Re: Sharpen Unibits? [Re: gibbonsseabee80] #170875 11/13/07 11:04 PM
renosteinke Offline
Gentlemen, you don't sharpen the conical part of the bit at all .... you work on the flat! Move that cutting edge back a mite - removing the dull lip, and making a new, sharp edge!
Re: Sharpen Unibits? [Re: renosteinke] #170883 11/14/07 04:37 AM
Alan Belson Offline
Run a small diamond lap along the flat faces, as Reno says, don't touch the diameter. This is a technique I use to keep router bits sharp. Don't overdo it, a diamond lap will remove metal very quickly. Sharpen little and often, as a keen edge lasts longer than a blunt one. A badly blunted cutter may not be revivable. I'm not sure what the 'titanium' coating is supposed to do, apart from giving the marketing departments a bit of snake oil!
One supplier;
http://www.eze-lap.com/
2020 National Electrical Code
Code (NEC)
2017 Master Electrician Exam Preparation Combos
2017 NEC Electrician
Exam Prep Combos:
Master / Journeyman
Niko
Niko
Campbell, CA
Show All Member Profiles
Admin 8
267,252 Are you busy
201,953 Re: Forum
190,560 Need opinion
Powered by UBB.threads™ PHP Forum Software 7.7.3
