Underground phone and coax depth?
by libellis - 02/08/23 02:21 PM
Al Hildenbrand - Minneapolis - obituary
by Bill Addiss - 02/03/23 07:38 PM
Violation?
by renosteinke - 01/27/23 09:52 PM
Does NEC 551.71 (F) apply to dwellings?
by BigB - 01/20/23 10:46 AM
Burger King crown sillyness
by wa2ise, December 11
240/208 to a house
240/208 to a house
by wa2ise, October 9
1 members (Scott35), 30 guests, and 12 robots.
#169163 09/27/07 09:31 PM
leland Offline OP
Hi All.
Not sure whats out there, Heres the scoop.
4' wide full height pantry, +- 6" between the shelfs and the door. Ful shelfs, I know a flourescent won't give any usefull light.
What is avail;able for vertical, down the inside of the pantry along the door jam.
Ideas and suggestions welcome.
Thanks leland.
leland #169166 09/28/07 12:19 AM
So you mean there is only +- 6" between the front of the shelf and the door jam?
How about fluorescent undercabinets lights from JUNO mounted vertically on the 6" available space.
Or the same fixtures mounted under every shelf?
Niko #169167 09/28/07 04:22 AM
leland Offline OP
Yes, I was thinking something along the lines (size) of like.... Rope lighting (example). Bi-fold doors
Each shelf or that way is way overkill.
leland #169176 09/28/07 08:14 AM
I have a fluorescent strip mounted above the door header in my pantry and the lighting is fine.
Remember that light will enter thru the open door. You are not trying to light a cave.
Jim M #169193 09/28/07 04:02 PM
leland Offline OP
Ya, considerd that, Thought that it would not filter down.
Maybe a reflector would help?
Pantry is about 24" deep, pretty standard, just solid shelfs.
Tools for Electricians
2023 NEC Now Available!
2020 Master Electrician Exam Preparation Combos
2020 NEC Electrician
Exam Prep Combos:
Master / Journeyman
CharlieE
CharlieE
Indianapolis
303,294 Are you busy
232,253 Re: Forum
217,014 Need opinion
