0 members (), 920 guests, and 10 robots.
#167714 08/18/07 03:33 PM
I am doing some research on PPE for arc flash. In a mine where MSHA is the code there is some confusion about what applies. I say the NEC applies and that OSHA applies. But I am hearing a lot of grumbling that OSHA does not apply unless MSHA does not cover it.
Is there a part of the NEC that talks about ARC Flash or is that just in OSHA?
Thanks
Windmiller
Workgear for Electricians
The NEC does not cover safe work practices. It only covers the installation of the system.
Don
Signage in 110.16?
Z
Zog Offline
MSHA references the NFPA 70E for your arc flash PPE questions. You can find alot of info on arc flash at www.epowerplus.com/training.htm
MV/HV Testing Specialist, "BKRMAN"
