ShoutChat Box
NEC 2017_392.22(B)(1)(b)
_What's the smallest width
by pcsailor - 09/15/19 07:58 PM
NEC Question_Cord-&-Plug EGC shorter then Neutral
by Bill Addiss - 09/15/19 03:19 PM
Does a 'normal 3ph-AC motor' include capacitors?
by gfretwell - 09/15/19 02:17 PM
Another NEC 2017 Question_240/24VAC Txfr-Neutral R
by Bill Addiss - 09/15/19 10:29 AM
Service Question
by HotLine1 - 09/14/19 01:43 PM
What is this for?
Plug terminals
1 registered members (pcsailor), 9 guests, and 8 spiders.
230V equipment on 208V #164136 05/25/07 11:11 PM
U
u2slow Offline OP
I looked at an automotive shop job today. Only this evening did I realize that the single-phase compressor (7.5hp) and the TIG machine want *230V*. blush The service is 120/208V 3-phase.
I know most of the options (I think)... what are the least expensive workarounds for this? Or what is the typical fix?
Re: 230V equipment on 208V [Re: u2slow] #164138 05/26/07 12:44 AM
NORCAL Offline
For the compressor buck boost transformer.Does the TIG welder have taps to change voltage,as a lot of welding equipment is designed for multi voltage use,just change tap to desired voltage.
Re: 230V equipment on 208V [Re: NORCAL] #164139 05/26/07 12:47 AM
SolarPowered Offline
Just a thought, it might be cheaper and or better to replace the TIG welder with a 3-phase 208 version, if the existing one doesn't have a 208 tap.
Re: 230V equipment on 208V [Re: SolarPowered] #164140 05/26/07 01:13 AM
U
u2slow Offline OP
I have to double check... it all just dawned on me this evening. The welder is a Miller Maxstar 150. Judging from the online owner's manual it appears to auto-sense between 115 and 230V.
OTOH, the mig machine has both a 200V and 230V rating, so its fine.
Re: 230V equipment on 208V [Re: u2slow] #164142 05/26/07 02:28 AM
Niko Offline
As NORCAL suggeste, Buck & Boost X-frmr.
and check the tabs on the welder.
http://acmepowerdist.com/products.asp?PAGE=/selguide/index.aspx
Use the selection guide on the left.
Re: 230V equipment on 208V [Re: Niko] #164154 05/26/07 11:30 AM
NORCAL Offline
Here is a link from Miller: http://www.millerwelds.com/products/tig/maxstar_150_sth/ This is one of 2 Maxstar models listed but this is copy and paste from same link:"Auto-Line™ Power Management technology circuitry automatically connects to 115 - 230 VAC, single-phase power without removing the cover to relink the power source."I did not read anything stating a 208V rating all data refered to operating @ 115 or 230V .
Re: 230V equipment on 208V [Re: NORCAL] #164172 05/26/07 05:19 PM
U
u2slow Offline OP
I'll give Miller's tech line a call on Monday. One local retailer said 208V is fine. Not that I'm going to take their word for it crazy
Based on the price for a 208/230V-20A buck/boost for the welder ($600 eek) I predict it will be cheaper to change the motor on the compressor if Devair says no-go.
Re: 230V equipment on 208V [Re: u2slow] #164194 05/27/07 03:52 PM
Active 1 Offline
From the miller web:
Auto line power management tecnoligy circuitry automatically connects to 115 - 230 VAC, single-phase power without removing the cover to relink the power source.
Wonder what type of plug it has.
This tig is a newer type that only weighs 13 pounds and my guess is more capacitors and electronics then transformers.
Other miller units had:
Universal Location Flexibility
Permits direct connection to almost any type of input power—115-575 VAC (varies by product), 1- or 3-phase, 50 or 60 Hz
Re: 230V equipment on 208V [Re: Active 1] #164198 05/27/07 06:27 PM
NORCAL Offline
"Wonder what type of plug it has."
You install your own......
Re: 230V equipment on 208V [Re: NORCAL] #164214 05/28/07 02:37 AM
I think the Multi-Voltage Plug(tm) setup on this one is rather innovative:
http://www.millerwelds.com/products/mig/millermatic_passport/index.php
2020 National Electrical Code
Code (NEC)
2017 Master Electrician Exam Preparation Combos
2017 NEC Electrician
Exam Prep Combos:
Master / Journeyman
The Watt Doctor
The Watt Doctor
Mont Belvieu, TX
Show All Member Profiles
Admin 11
258,560 Are you busy
194,143 Re: Forum
183,636 Need opinion
Powered by UBB.threads™ PHP Forum Software 7.7.3
