One breaker only works when the dryer is running
by HotLine1 - 10/03/23 02:42 PM
Elk’s Lodge 11th hour ritual chime clock
by gfretwell - 10/01/23 02:06 AM
Strange breaker tip problem
by gfretwell - 09/25/23 08:13 PM
An impossible Support Violation
by gfretwell - 09/12/23 04:29 PM
How are you Jersey folks about the windmills?
by gfretwell - 09/08/23 02:21 PM
0 members (), 33 guests, and 11 robots.
#163899 05/20/07 05:04 PM
Hi All,
I was asked by a young fellow if his Ipod would work OK in europe with a convertor he bought. I have not seen the specs but thought someone here could educate me. My 1st thought would be 50Hz vs 60hz?
Thanks Ob
Obsaleet #163901 05/20/07 05:42 PM
3
Most of the Ipod adapters are 100-250 VAC 50-60 Hz. We had a young lass living with us who had an Ipod from the USA that we powered up through an adapter lead to run on 240VAC 50Hz with no problems.
32VAC #163905 05/20/07 06:48 PM
Walks over to desk, grabs iPod Charger.
Lemme see here, 100-240VAC, 50-60Hz. You're good to go.
Ian A.
Thanks Guys! I figued 1 of u woul have an Ipod.:)
Ob
Obsaleet #163933 05/20/07 09:40 PM
Most computing gear is set up to accept both voltages, both frequencies. It's just a matter of getting the correct cord (for IEC-equipped components) or adapter to make the plug fit. But, you should always check; some older computer power supplies have a switch in the back that needs to be moved from 115 to 230.
Can't iPods charge off USB?
Yep, and firewire too (that includes the videos and Nanos, they just cant sync via Firewire.
Ian A.
Even if the voltage was a problem (to be overcome with a transformer, naturally), the frequency difference is unlikely to be a problem in this case, since output is just being converted to DC anyway.
Tools for Electricians
2023 NEC + Exam Prep Study Guides Now Available!
2020 Master Electrician Exam Preparation Combos
2020 NEC Electrician
Exam Prep Combos:
Master / Journeyman
renosteinke
renosteinke
Blue Collar Country
lemahj 3
311,332 Are you busy
237,652 Re: Forum
221,415 Need opinion
