ShoutChat Box
Lock-down Thread
by JoeTestingEngr - 04/18/21 12:35 AM
Where is Everyone?
by gfretwell - 04/17/21 07:32 PM
Upside Down ThreeWay
by Trumpy - 04/17/21 06:25 AM
Thought this was funny
by Trumpy - 04/17/21 06:22 AM
How's all our Non-US folks doing?
by Trumpy - 04/17/21 05:37 AM
Facebook follies, bad wiring
FPE in Germany pt.2
0 registered members (), 24 guests, and 14 spiders.
GFCI Protection on Hot Tub #163219 05/04/07 06:38 AM
RonS Offline OP
I went by a prospective customers home yesterday to give an estimate on wiring a hot tub. Upon inspection of the tub the instructions indicate a three wire connection. Two hots and a ground. No neutral connection in the hot tub, no internal GFCI protection provided. There is a neutral generated inside the internal components of the hot tub for lighting and control circuits. Without a neutral connection how would one go about protecting the hot tub with a GFCI breaker. Has anyone run across this before? If I cannot provide the GFCI protection required I will have to tell the customer I cannot do the work.
Re: GFCI Protection on Hot Tub [Re: RonS] #163225 05/04/07 08:59 AM
ghost307 Offline
You need to use a 2-pole GFI circuit breaker.
You don't need a neutral to detect ground fault, only a circuit path that can be monitored for any current that isn't accounted for.
12 Amps out on one wire, 12 Amps back on the other...everything's fine.
12 Amps out on one wire, 11.9Amps back on the other...something's wrong with the circuit.
Ghost307
2020 National Electrical Code
Code (NEC)
2020 Master Electrician Exam Preparation Combos
2020 NEC Electrician
Exam Prep Combos:
Master / Journeyman
MarkC10
MarkC10
CA, Inland Empire
Show All Member Profiles
Trumpy 11
277,733 Are you busy
211,312 Re: Forum
198,347 Need opinion
Powered by UBB.threads™ PHP Forum Software 7.7.3
