Underground phone and coax depth?
by libellis - 02/08/23 02:21 PM
Al Hildenbrand - Minneapolis - obituary
by Bill Addiss - 02/03/23 07:38 PM
Violation?
by renosteinke - 01/27/23 09:52 PM
Does NEC 551.71 (F) apply to dwellings?
by BigB - 01/20/23 10:46 AM
Burger King crown sillyness
by wa2ise, December 11
240/208 to a house
240/208 to a house
by wa2ise, October 9
1 members (Scott35), 33 guests, and 13 robots.
#162639 04/22/07 08:43 PM
F
I just want to pass the word just becarefull about using this raceway.
this is the link you will see the photo Arlington raceway link
so if you actally run romax wires you will get some nasty suprised from the electrical inspectors but this is fine for data/ commuation cable that i think it will have no issuse with that but for power [ both line and low voltage ] have to watch for derating as well.
I just want to give you guys a head up before you use this product so you can make a wise choice to do next
Merci , Marc
I've used this a few times without a problem. It's not a raceway but a support system.
F
ok i just want to make sure but that " support " system is three sided instead of 4 side but how did the inspector say anything about that and also my condsering is the amout of romax wire in the support way so i am open to other suggest about this ?/
thanks , Marc
Other than "bundling" and the associated derating I don't see a problem
Tools for Electricians
2023 NEC Now Available!
2020 Master Electrician Exam Preparation Combos
2020 NEC Electrician
Exam Prep Combos:
Master / Journeyman
CharlieE
CharlieE
Indianapolis
303,294 Are you busy
232,253 Re: Forum
217,014 Need opinion
