May I backfeed 3 phase transformer?
by dsk - 10/22/21 04:37 AM
Wire sizing
by gfretwell - 10/21/21 10:12 PM
GFCI's pops in large numbers
by dsk - 10/21/21 02:03 AM
Need some info on Japanese outlets, 200V 15A
by andey - 10/20/21 08:05 AM
nec 110.3 (B)
by watersparkfalls - 10/19/21 07:09 AM
240/208 to a house
240/208 to a house
by wa2ise, October 9
Now you know.
Now you know.
by Tom_Horne, September 7
0 members (), 9 guests, and 23 robots.
#161980 04/11/07 08:53 AM
Since most manufacturers of single station smoke alarms are limiting you to between 10 and 12 units on a circuit, what does one do when you need more than 12 units for a home?
George Little
2017 / 2014 NEC & Related Books and Study Guides
I suppose you will need to find a manufacturer that doesn't have the restriction or find one with a "repeater" type adapter to link 2 loops.
In real life I would expect a home that big to have a real alarm system. Even my wife's micro mansions (2000-4000 sq/ft) had a system that picked up the smokes, CO, pool alarm and intrusion alarm.
gfretwell #162026 04/12/07 04:54 AM
Greg some areas will not allow a fire alarm system to take the place of the required smoke alarms.
I don't know the solution to the question.
iwire #162046 04/12/07 12:53 PM
Bob that seems strange to me but I never underestimate the absurdity of government.
Off the cuff, I don't see a problem.
The limit seems to be based upon the current they need when in alarm. This has nothing to do with interconnection.
I would think that you could continue to link them all together with that third wire, even if the detectors are powered by different circuits.
I just inspected a home that had a need for 31 yes THIRTY ONE, smoke alarms and while it appears that it would be possible to interlock them electrically with some sort of relay system- the manufacturers tell me that that's not allowed due to the listing. As for a Fire alarm system- The State of Michigan will recognize it as satifying the requirements as called out in the Michigan Residential Code (same as the IRC only with the Michigan spin).
George Little
I am wrong about the alarm system. My wife says no, they use stand alone smokes.
Everything else is on the central system.
Give me a break, I have already been punished wink
gfretwell #162079 04/12/07 08:51 PM
Reno, what exactly does go down that 3d wire and would the smokes being on opposite phases change anything?
Do all brands work the same way?
I have never really looked into this.
gfretwell #162086 04/12/07 10:09 PM
As I understand it, that third wire only links some contacts together ... it there's continuity in one detector, they all sound off.
F
Yes that true John but if you have third wire interconneted and also the netural line as well as common return [ i have little trouble to grasp this idea how it work ]
but for hot's line it can be on common or diffrent phase or leg but i am sure but not excat answer for this one but i am thinking out loud that both red [ interconnection ] and white wires to actavie it
Merci , Marc
Tools for Electricians
2020 Master Electrician Exam Preparation Combos
2020 NEC Electrician
Exam Prep Combos:
Master / Journeyman
BEAMEUP
BEAMEUP
WA
dsk 7
284,816 Are you busy
217,386 Re: Forum
203,723 Need opinion
