0 members (), 69 guests, and 14 robots.
#160245 08/30/05 09:15 PM
The sound guy had to 'fish' a wire- so, naturally, he made a hole somewhat larger than the wire.
What I'd like to know is- are there fittings used to close this hole afterwards? Or, do you guys also fix sheetrock?
I doubt what this guy did- walk away, leaving a 2" hole- is considered proper.
- renosteinke
#160246 08/30/05 09:29 PM
I have seen a split blank cover with a hole in the middle, put in a LV ring.
#160247 08/31/05 01:31 AM
It looks like a molded VGA cable, which is going to require at least a 1.5" hole to get it thru the wall..
I agree, use a LV ring, and a split cover..
They also make plastic rings designed for desks, with a snap in cover, but they are probably not suited for walls..
#160248 08/31/05 02:34 AM
e57 Offline
For a VGA, or serial connector there aren't too many other ways... Short of cutting the cord, or a 2-3" grommet. Reno, is this a fire wall?
#160249 08/31/05 10:04 PM
E57, this is not a fire wall- just a gypsum faced residential wall. You can see it in the picture- this wall ia well under two feet long. At least- the part where the hole is.
The other wall- the one with the "wiremold" box and antennae jack- is an exterior wall, and not fire-rated.
Now, I'd like to brag a litle, but that piece of equipment is hiding the part of the wall that I had worked on previously. There is a receptacle on the "away" side of the wall; previously I had tapped into that box to feed an outside receptacle on the opposite side of the wall from the "wiremold" box. I had patched the wall.
This guy- or the complex maintenance man- had in turn tapped into the outside receptacle to feed back into the wall, where he in turn fed another receptacle in the wiremold box.
The point is- I had hacked up the wall some, and then fixed it. This guy was happy to leave a big, fat hole. It just seems like poor workmanship.
I realise that these guys use different materials than electricians- but I would have expected the hole to be closed in some manner!
#160250 09/01/05 04:44 AM
Time for some expando foam.
#160251 09/01/05 07:36 AM
Expando foam ?? NOthing to do with the serial connection ??
If you used that foam in my house to trim out that cable I would be a little upset, when a product like this is available : http://siemon.com/apps/Utilities/sh...audio-video-modules_MX-D4F-15-XX_big.jpg
Cut in a low voltage mounting bracket connect the cable that was fished in the wall to the back of the frame that I linked and blank up the extra 4 openings, then install a Decora faceplate and that VGA cable looks like it was installed professionally.
Now that I look at the pic a little closer I see there is another part to that cable besides the VGA.
What is that ? I want to see if I can put something together to clean this up.
#160252 09/01/05 12:39 PM
Mkoloj, Please do not confuse my lousy attempt at humor with incompetence. I have built my own houses more than once. A proper drywall repair is no problem for me. What would be a problem for me is the way the guy walked away from a mouse hole like this one. He would not get away with that at my house.
#160253 09/01/05 02:00 PM
Good thing you were joking, I thought for a minute that the expanding foam was an option to somebody. That hole he bored in the wall does not even look like it needs to be repaired, maybve a little more cut out to be bale to fit a plate in the wall to dress that up a little. That is not even a bad install, maybe a little unsightly to the trained eye, but the one's I love the best are the network guys who just cut a little hole in an acoustical ceiling tile and "jungle drop" right against the wall.
Is the cable pictured even listed to be installed in the wall ????
#160254 09/01/05 03:07 PM
What is that thing and what is it doing there anyway??
-Hal
