ShoutChat Box
Lock-down Thread
by gfretwell - 03/03/21 12:38 PM
Questioning the electrical norms
by Texas_Ranger - 03/02/21 05:21 PM
Northern Tool Recalls Powerhorse Generators
by Admin - 02/25/21 09:49 PM
You will never guess
by gfretwell - 02/25/21 07:48 PM
Facebook follies, bad wiring
FPE in Germany pt.2
1 registered members (Scott35), 30 guests, and 19 spiders.
Fire Rating? #160218 07/08/05 06:04 AM
electure Offline OP
In a firewall, I have to use rated steel boxes for my electrical work. Doesn't the use of these "data rings" by the low voltage crowd destroy the rating of that firewall?
Renosteinke
Study Guides for VDV / Structured Cabling Installers
Voice, Data, Video, (VDV) Fiber Optics, Communications, Low Voltage,
Fire Alarm, Electronic Security Systems Installations & Related
NTC Low Voltage Training & NICET Exam Study Guides
Re: Fire Rating? #160219 07/08/05 08:21 AM
hbiss Offline
Have to admit even I am guilty of that from time to time. [Linked Image]
I would say yes, a steel box should be used depending on the rating of the wall and the proximity to any other boxes.
-Hal
Re: Fire Rating? #160220 07/08/05 09:09 AM
gfretwell Offline
When I was doing "Data" we had to respect "penetrations" just like everyone else. The problem is data doesn't usually get permitted/inspected. You will get caught by the life safety inspector, usually as part of an unrelated inspection.
In the case of this picture he would be looking at the exit light and say "that ain't gonna work" when he sees the other hole in his firewall.
Re: Fire Rating? #160221 07/18/06 06:38 PM
F
FrankC Offline
Don't get caught defeating the rating of a firewall. The liability of that is NOT worth it.
Go to Hilti.com, and look under firestop products. There is some good info there.
Re: Fire Rating? #160222 07/20/06 02:40 AM
Scott35 Online Happy
Renosteinke:
Heck ya, it does!!!
Typical installations in my area (Southern California), for _ANY OUTLETS_ in rated walls / lids, is as follows:\
<OL TYPE=A>
[*] The outlet would be (compatible to) a 4s box, with a 1 (or 2) Gang Ring mounted to it,
[*] The 4s Box would be covered with a "Fire Pad",
[*] The Low Voltage Cabling would enter the box via 3/4" EMT, which extends "Outside" of the rated wall / area.
</OL>
Scott35
Re: Fire Rating? #160223 07/22/06 06:45 AM
*** BUMP-A-DEE-BUMP ***
Bumping zee Thread up again for discussion-ary purposes!
`El-Scotto35
Re: Fire Rating? #160224 07/22/06 11:09 AM
renosteinke Offline
Scott, my original intention in posting this pic was two-fold:
I wanted to illistrate the importance of knowing more than just "your" part of the code; and,
I wanted to shame some data guys out there into actually thinking about how they're supposed to do things- as opposed to using all the short-cuts they've been able to get away with, as their work takes place after the inspector has left!
Re: Fire Rating? #160225 07/22/06 06:10 PM
hbiss Offline
You are wasting your time. Data guys, better known as computer geeks, have no shame.
-Hal
Re: Fire Rating? #160226 07/22/06 07:05 PM
Trumpy Offline
Hal,
It's only after a fire that these things are picked up by investigators.
Fire-walls aren't put there for the sheer fun of it.
These people should be made an example of. [Linked Image]
Re: Fire Rating? #160227 07/22/06 09:43 PM
gfretwell Offline
Part of my job was to teach them some shame ... or at least to get the problem fixed and get their boss a bill.
2020 National Electrical Code
Code (NEC)
2020 Master Electrician Exam Preparation Combos
2020 NEC Electrician
Exam Prep Combos:
Master / Journeyman
watersparkfalls
watersparkfalls
Washington...Not DC
Show All Member Profiles
275,588 Are you busy
209,503 Re: Forum
196,881 Need opinion
Powered by UBB.threads™ PHP Forum Software 7.7.3
