Al Hildenbrand - Minneapolis - obituary
by bcpappas - 02/02/23 08:01 PM
Violation?
by renosteinke - 01/27/23 09:52 PM
Does NEC 551.71 (F) apply to dwellings?
by BigB - 01/20/23 10:46 AM
Power submeter connections
by HotLine1 - 01/19/23 09:09 AM
Burger King crown sillyness
by wa2ise, December 11
240/208 to a house
240/208 to a house
by wa2ise, October 9
0 members (), 24 guests, and 20 robots.
#159781 01/27/05 05:17 PM
Does any one know of a 8-port plate for speaker connection. The kind that uses the red/black push ins with bare wire. I'd post pic do not know how.
2020 NEC & Related Reference & Study Guides
Pass Your Exam the FIRST TIME with these Exam Prep Combos:
>> Master Electrician Exam Prep     >> JourneyMan Electrician Exam Prep
#159782 01/27/05 07:16 PM
For a single gang box opening? try this link to the niles web site bottom right side. These are the binding post kind, but work just as good as the push-in type
http://www.nilesaudio.com/products/saco5w.html
[This message has been edited by BEAMEUP (edited 01-27-2005).]
#159783 01/27/05 07:44 PM
Not a big fan of those spring clips. Never saw more than 2 pair per gang and I very vaguely remember seeing maybe a two gang somewhere.
Best bet if you want to do this is to get the spring clips separately and make your own plate out of a large enough blank. Question is where to get them, I know I've seen those too someplace.
Another alternative is the bananna jack connectors. Leviton make bananna jack inserts for their Quick-Port plates and there is a 2 gang with 12 ports (6 speakers).
Bananna jacks require bananna plugs on the cable end but that's a good thing because at least they can be color coded and labeled. It's too easy for someone to mess up the connections with spring clips later on.
Actually I'm not a big fan of any of these termination methods because of the possibility of wrong connections and shorts due to the large exposed metallic parts of the bananna jacks.
I would much rather bring a bundle of cables out of a wall box or mud ring through a suitable wall plate with a bushed hole and run them directly to the equipment.
-Hal
[This message has been edited by hbiss (edited 01-27-2005).]
#159784 01/30/05 06:55 PM
Thanks, I have not seen any 8port either. H.O wants to add to existing right now they are wire nuted together. Any know how those bananna jacks are.
#159785 01/31/05 09:13 AM
I don't like those clip connections either. I figure if you're going to the trouble of installing all this you might as well use some good solid connectors.
Parts Express (Ohio) carry a fair range of audio accessories for fitting standard boxes. You might find something there of use.
www.partsexpress.com
[This message has been edited by pauluk (edited 01-31-2005).]
Tools for Electricians
2023 NEC Now Available!
2020 Master Electrician Exam Preparation Combos
2020 NEC Electrician
Exam Prep Combos:
Master / Journeyman
renosteinke
renosteinke
Blue Collar Country
BigB 4
triple 3
303,003 Are you busy
232,028 Re: Forum
216,769 Need opinion
