How's Florida doing with Hurricane Ian?
by Bill Addiss - 09/28/22 12:41 PM
Tough being a lineman's kid
by Bill Addiss - 09/28/22 12:39 PM
GFCI's pops in large numbers
by dsk - 09/26/22 04:35 AM
AFCI’s Revisited
by sparky - 09/24/22 09:58 AM
NFPA Price Increase Coming
by Bill Addiss - 09/23/22 02:22 PM
240/208 to a house
240/208 to a house
by wa2ise, October 9
Now you know.
Now you know.
by Tom_Horne, September 7
0 members (), 36 guests, and 23 robots.
mkoloj Offline OP
http://www.ablecomm.com/bnewneatpowf.html
I saw this product offered and it left me wondering how this could be done? Also can anyone elaborate or has anyone heard of such a thing as the "protective plastic sleeve to cover the phone wiring if it has to pass though the wall box, as required by the National Electric Code."
2020 NEC & Related Reference & Study Guides
Pass Your Exam the FIRST TIME with these Exam Prep Combos:
>> Master Electrician Exam Prep     >> JourneyMan Electrician Exam Prep
Here is a Leviton PDF for the product. http://assets.twacomm.com/pdf/24628.pdf
steve
Steve
mkoloj Offline OP
So I take it from the instructions for this device that it is ok to have power and telephone in the same box as long as you have the plastic protective tubing on the phone cable and maintain .25" from the 120V conductors??
NEC 800-52(a)1(c)1 exceptions say it's ok.
steve
Steve
e57 Offline
First time I saw one I said "No way"!
It has two options:
Phone wires inside the outlet box.
And Phone wires stubbed out throught the rock below the edge of the box.
I prefer the later.
mkoloj Offline OP
Thank you gentlemen for your responses I was looking for solutions to this problem with the "wall wart" having the wire strung across the wall to an outlet. It looks like I have found it, anyone think of any other possible solutions that are compliant?
Never done it but I see no reason you couldn't run CL2 wiring to the phone jack location with the telephone wiring. Splice it onto a tail with the power plug on it made by cutting the cord from the original transformer. Exit the jack the same way these guys do it and plug it into the phone. You could then locate the transformer in the basement or some other suitable location.
-Hal
mkoloj Offline OP
I like that idea would save the $30 for that leviton plate
Matter of fact you could put the power on the black/yellow pair if you are using 22ga quad IW and the situation permits. That's what we used to do with the old Princess and other phones with lighted keypads. Tip/ring on red/green, 10vac from a plug-in transformer on the black/yellow.
-Hal
hbiss, are you saying that most or all of the phones that normally need a wall-wart are designed to alternatively take power from the black/yellow pair? [Linked Image]
Tools for Electricians
2020 Master Electrician Exam Preparation Combos
2020 NEC Electrician
Exam Prep Combos:
Master / Journeyman
JoeKP
JoeKP
Berkley, MA
297,555 Are you busy
228,368 Re: Forum
213,242 Need opinion
