ShoutChat Box
NESC question
by gfretwell - 07/14/20 09:43 PM
120/208 gives 240? please clarify
by gfretwell - 07/14/20 01:03 PM
Questioning the electrical norms
by HotLine1 - 07/13/20 12:40 PM
You will never guess
by BigB - 07/13/20 09:45 AM
Ceiling Fan Capacitor Question
by libellis - 07/11/20 01:45 PM
Facebook follies, bad wiring
FPE in Germany pt.2
0 registered members (), 23 guests, and 15 spiders.
Sub panel hight #154430 08/18/05 10:54 AM
moody Offline OP
*sub panel height
hay im new here
i started out at a vo-tech school and just finished the 2nd year of that. after that i worked for wagner electric for one year before i quit and switched to monmouth electric which is where i am now.
I am going to be installing a sub panel this weekend and was wondering if there were any rules/codes about the hight of the sub.
If there are please post them here
PS - this is in eastern NJ
Thanks
[This message has been edited by moody (edited 08-18-2005).]
He who shall not be known
Building Codes & Related References
Re: Sub panel hight #154431 08/18/05 03:07 PM
gfretwell Online Content
The highest handle has to be 6' 6" or less.
Re: Sub panel hight #154432 08/18/05 05:37 PM
Ryan_J Offline
Do you mean 6'7"? [404.8(A)], [240.24(A)].
Ryan Jackson,
Salt Lake City
Re: Sub panel hight #154433 08/18/05 09:42 PM
moody Offline OP
its 6/7
what do you mean by the highest handle...
the top breaker?
Re: Sub panel hight #154434 08/18/05 11:03 PM
Sure 6'7 in boots. I have my boat shoes on.
Re: Sub panel hight #154435 08/19/05 12:06 AM
moody Offline OP
whatever, ill just put it no higher than 6'6"
just to be safe
thanks for the info
Re: Sub panel hight #154436 08/19/05 09:18 AM
rad74ss Offline
The height is to the center of the handle on the breaker or operating mechanism.
I also keep the center of fuses at that height.
But that begs the old question of whether the fuse is really considered a "switch". I consider it so but it is always good to see if there is someone who knows of the exception to the addendum that would allow different heights.
Re: Sub panel hight #154437 08/19/05 01:20 PM
Ryan_J Offline
Gee...why do they call you moody?
Ryan Jackson,
Salt Lake City
Re: Sub panel hight #154438 08/19/05 04:26 PM
iwire Offline
404.8 Accessibility and Grouping.
(A) Location. All switches and circuit breakers used as switches shall be located so that they may be operated from a readily accessible place. They shall be installed so that the center of the grip of the operating handle of the switch or circuit breaker, when in its highest position, is not more than 2.0 m (6 ft 7 in.) above the floor or working platform.
Re: Sub panel hight #154439 08/19/05 10:27 PM
moody Offline OP
why do they call me moody?
i just started the name (dont remember why or when) but it was years ago and it stuck [Linked Image]
2020 National Electrical Code
Code (NEC)
2017 Master Electrician Exam Preparation Combos
2017 NEC Electrician
Exam Prep Combos:
Master / Journeyman
The_Lightman
The_Lightman
Orlando, Fl, USA
Show All Member Profiles
Admin 8
267,437 Are you busy
202,066 Re: Forum
190,641 Need opinion
Powered by UBB.threads™ PHP Forum Software 7.7.3
