ShoutChat Box
2020 code
by shortcircuit - 01/22/20 01:16 PM
Where are this kind of fuses used?
by dsk - 01/22/20 01:09 PM
Electrician and Telecomunications
by djk - 01/21/20 08:54 PM
Low voltage fuses,where should they fit?
by dsk - 01/19/20 11:31 AM
ID strange fuses. never seen...
by dsk - 01/19/20 11:22 AM
FPE in Germany pt.2
FPE Breaker panel in germany
1 registered members (Scott35), 101 guests, and 10 spiders.
disposer/dish circuit #154392 07/06/05 12:41 AM
watersparkfalls Offline OP
i want to know if anybody can help me calculate if i can put a 1/2 HP disposer motor and a dishwasher that draws a nameplate or 9.1 amps on a 20 amp circuit.
Building Codes & Related References
Re: disposer/dish circuit #154393 07/06/05 11:39 AM
gfretwell Offline
Nominal FLA on a 1/2 HP motor is 9.8a (plus 25%) added to 9.1a seems to be too much for a multiple motor load.
If you are cord and plug connected they each do represent less than 50% of circuit ampacity so it might be "hold your nose" legal. I have seen this go both ways but the preferable solution is a multiwire circuit with 2 phases feeding the duplex.
Re: disposer/dish circuit #154394 07/07/05 01:12 AM
thanks gf i just wondered if possible...
could you elaborate on the 50% since cord connected dishwashers are feasible and do provide disconnecting means for motor.
h2o
Re: disposer/dish circuit #154395 07/07/05 11:39 AM
gfretwell Offline
It all gets down to how you read
210.23(A)(2) Utilization Equipment Fastened in Place. The total rating of utilization equipment fastened in place, other than luminaires (lighting fixtures), shall not exceed 50 percent of the branch-circuit ampere rating where lighting units, cord-and-plug-connected utilization equipment not fastened in place, or both, are also supplied.
Most inspectors would say all fixed in place equipment must be less than 50% but I have seen this stretched to say any one piece can't exceed 50%, particularly on an intermittant load like a disposal.
Vote me for "all".
Re: disposer/dish circuit #154396 07/07/05 09:03 PM
renosteinke Offline
One caution here....look at the FLA on the disposal, and not the "horsepower" rating. I have seen a lot of inflated "horsepower ratings" over the years.
Re: disposer/dish circuit #154397 07/12/05 08:46 PM
Larry Fine Offline
"...lighting units (or) cord-and-plug-connected utilization equipment not fastened in place..."
Neither describe either a dishwasher or a disposer, so 210.23(A)(2) doesn't apply.
I routinely place both of these on a 20-amp circuit. A disposer is probably the epitome of an intermittent load.
Larry Fine
Fine Electric Co.
fineelectricco.com
Re: disposer/dish circuit #154398 07/12/05 08:55 PM
Larry Fine Offline
According to Insinkerator specs, the 1/2HP Badger 5 has an average current draw of 6.9A.
http://www.insinkerator.com/pdf/badger5.PDF
Larry Fine
Fine Electric Co.
fineelectricco.com
Re: disposer/dish circuit #154399 08/10/05 08:27 AM
dlhoule Offline
Good subject. I have been told that they make a 3 way switch that can be used in these applications. One position for dishwasher and other for disposal. Now having said that I personally have not seen one. Do they make them?
Re: disposer/dish circuit #154400 08/10/05 09:23 AM
BobH Offline
Any 3-way rated for the load would work.
Re: disposer/dish circuit #154401 08/10/05 04:43 PM
Ryan_J Offline
I am moving this to the NEC section.
Ryan Jackson,
Salt Lake City
2020 National Electrical Code
Code (NEC)
2017 Master Electrician Exam Preparation Combos
2017 NEC Electrician
Exam Prep Combos:
Master / Journeyman
MarkC10
MarkC10
CA, Inland Empire
Show All Member Profiles
Trumpy 12
dsk 6
262,456 Are you busy
197,587 Re: Forum
186,597 Need opinion
Powered by UBB.threads™ PHP Forum Software 7.7.3
