90
11
If I want to build a screened in porch, what book would I get to find out the span ratings on different pieces of lumber. Is that BOCA? Also if I want to know required roof pitches etc.
Thanks.
In which State do you live?
Ryan Jackson, Salt Lake City
Use this list to narrow it down a bit.
Illinois Jurisdictions
Aurora
International Building Code ICC Electrical Code International Fire Code International Fuel Gas Code International Mechanical Code International Plumbing Code International Property Maintenance Code International Residential Code
Bartlett International Building Code International Energy Conservation Code International Fire Code International Fuel Gas Code International Mechanical Code International Property Maintenance Code International Residential Code
Belvidere International Building Code International Residential Code
Cahokia, Village of International Building Code International Energy Conservation Code International Fire Code International Fuel Gas Code International Mechanical Code International Plumbing Code International Private Sewage Disposal Code International Property Maintenance Code International Residential Code
Cantrall International Building Code ICC Electrical Code International Energy Conservation Code International Fire Code International Fuel Gas Code International Mechanical Code International Private Sewage Disposal Code International Property Maintenance Code International Residential Code International Zoning Code
Carbondale International Building Code International Property Maintenance Code International Residential Code
Chicago International Energy Conservation Code
Clear Lake Villa International Building Code ICC Electrical Code International Energy Conservation Code International Fire Code International Fuel Gas Code International Mechanical Code International Private Sewage Disposal Code International Property Maintenance Code International Residential Code International Zoning Code
Collinsville International Building Code International Energy Conservation Code International Existing Building Code International Fire Code International Fuel Gas Code International Mechanical Code International Property Maintenance Code International Residential Code
Cortland 2000 International Building Code 2000 International Energy Conservation Code 2000 International Fire Code 2000 International Fuel Gas Code 2000 International Mechanical Code 2000 International Plumbing Code 2000 International Residential Code
Des Plaines International Building Code ICC Electrical Code International Energy Conservation Code International Fire Code International Fuel Gas Code International Mechanical Code International Private Sewage Disposal Code International Property Maintenance Code International Residential Code
East Moline International Building Code International Fire Code International Fuel Gas Code International Mechanical Code International Property Maintenance Code International Residential Code
Elgin International Building Code International Mechanical Code International Property Maintenance Code International Residential Code
Forsyth International Building Code International Mechanical Code International Property Maintenance Code International Residential Code
Fox River Grove International Building Code International Energy Conservation Code International Fire Code International Fuel Gas Code International Mechanical Code International Plumbing Code International Property Maintenance Code International Residential Code
Galesburg International Building Code International Fuel Gas Code International Mechanical Code International Residential Code
Hampshire 2000 International Building Code 2000 International Energy Conservation Code 2000 International Fire Code 2000 International Fuel Gas Code 2000 International Mechanical Code 2000 International Plumbing Code 2000 International Residential Code
Hazel Crest International Mechanical Code International Plumbing Code
Highland International Building Code International Mechanical Code International Property Maintenance Code International Residential Code
Kankakee International Building Code International Mechanical Code International Property Maintenance Code International Residential Code
Kirkland 2000 International Building Code 2000 International Energy Conservation Code 2000 International Fire Code 2000 International Fuel Gas Code 2000 International Mechanical Code 2000 International Plumbing Code 2000 International Residential Code
LaSalle International Building Code International Fire Code International Fuel Gas Code International Mechanical Code International Property Maintenance Code International Residential Code
Lee 2000 International Building Code 2000 International Energy Conservation Code 2000 International Fire Code 2000 International Fuel Gas Code 2000 International Mechanical Code 2000 International Plumbing Code 2000 International Residential Code
Lemont International Building Code International Energy Conservation Code International Fuel Gas Code International Mechanical Code International Property Maintenance Code International Residential Code
Lockport - Northwest Homer Fire District International Building Code International Fire Code
Maple Park 2000 International Building Code 2000 International Energy Conservation Code 2000 International Fire Code 2000 International Fuel Gas Code 2000 International Mechanical Code 2000 International Plumbing Code 2000 International Residential Code
Montgomery (adopted but may not yet be effective) International Building Code International Residential Code
Morton International Building Code
Mundelein, Village of International Building Code International Fire Code
Naperville International Building Code ICC Electrical Code International Energy Conservation Code International Fire Code International Fuel Gas Code International Mechanical Code International Property Maintenance Code International Residential Code
Normal International Mechanical Code International Property Maintenance Code International Residential Code
Oak Park (Effective April 1, 2004) International Building Code ICC Electrical Code International Energy Conservation Code International Fire Code International Fuel Gas Code International Mechanical Code International Residential Code
Peoria International Energy Conservation Code
Peotone International Building Code International Mechanical Code International Property Maintenance Code International Residential Code
Quincy International Building Code International Fire Code International Property Maintenance Code International Residential Code
Rockford International Energy Conservation Code
Rock Island International Building Code International Energy Conservation Code International Fire Code International Fuel Gas Code International Mechanical Code International Residential Code
Sangamon County International Building Code ICC Electrical Code International Energy Conservation Code International Fire Code International Fuel Gas Code International Mechanical Code International Private Sewage Disposal Code International Property Maintenance Code International Residential Code International Zoning Code
Schaumburg International Building Code International Energy Conservation Code International Existing Building Code International Fire Code International Fuel Gas Code International Mechanical Code International Plumbing Code International Property Maintenance Code International Residential Code
Seneca International Residential Code
Shabbona 2000 International Building Code 2000 International Energy Conservation Code 2000 International Fire Code 2000 International Fuel Gas Code 2000 International Mechanical Code 2000 International Plumbing Code 2000 International Residential Code
Union 2000 International Building Code 2000 International Energy Conservation Code 2000 International Fire Code 2000 International Fuel Gas Code 2000 International Mechanical Code 2000 International Plumbing Code 2000 International Residential Code
Vernon Hills International Building Code International Fire Code International Fuel Gas Code International Mechanical Code International Property Maintenance Code International Residential Code
Washington International Building Code International Residential Code
Western Springs International Mechanical Code International Plumbing Code
Yorkville 2000 International Building Code 2000 International Energy Conservation Code 2000 International Fire Code 2000 International Fuel Gas Code 2000 International Mechanical Code 2000 International Plumbing Code 2000 International Residential Code
Great answer(s)(s)!! but you know great answers always spawn more questions. First, where did you get that list? International building code, and International residential code, are these what architects use to spec. building components?
Before I assault you with any more questions, I'll explain:
A contractor I wire room additions for has asked me to do his drawing for him in AutoCAD. I'd love to. I love AutoCAD and don't have enough reasons already to use it. So I'll draw them and if the village requires an arch. stamp, he'll have it reviewed and stamped. But I want to draw them so they need no revision, but I don't want to overbuild it just because I don't know any better.
I have plenty of similar room plans that have already been built to look at for reference. I would however prefer to double-check requirements. I have seen it plenty of times when an arch. doesn't know the NEC, they over-spec it to cover themselves.
Plus I have grumbled before with other trades about how the print we are looking at can't or shouldn't be built that way, and how I have always thought it should be a requirement for arch.'s and engineers to spend a few years in the field with tools as part of their internship. Not that I'm on my way to becoming an arch., but now is my chance to draw a plan the way it is actually going to be built.
or.... Do you have any recommendations for building code discussion forums like this one?
Nevermind. I just got done surfing for a little while here and think I found most the answers I was looking for. I found that list at the ICC site. great site. Also found this site helpful. http://www.mcvicker.com/resguide/toc.htm Thanks for you help Ryan_J.
Your very welcome. Let me know if theres anything I can help you with. ![[Linked Image]](https://www.electrical-contractor.net/ubb/smile.gif)
