0 members (), 227 guests, and 28 robots.
#15343 10/14/02 12:18 PM
C-H Offline OP
Hi!
It seems as if the once so simple fuses in the fusebox aren't so simple anymore. First came the breaker with electromagnetic and thermal trip, then the ground fault circuit interrupter measuring current balance and now arc fault circuit interrupters with a microprocessor. Soon the "fuse box" will run Windows, crashing once a week... [Linked Image]
Here's my question/idea: Are fully electronic breakers the future? Instead of having a thermal trip, it measures the current, checks the waveform and possible imbalance between the two wires. It will still have to have a magnetic tripping mechanism, of course.
I can think of two advantages of such a design:
1.) The overload protection doesn't depend on the number and load of the breakers next to it. No derating --> no need to put oversize breakers to avoid nuisance trips--> less risk of fire.
2.) Breaker discrimination is facilitated, since you can program a real trip curve, not just "oh, it will trip somewhere between three and five times the rated current"
If the price is right we could have GFI and perhaps AFI proctection on all branch circuits --> less risk of people killed by things like broken switches and receptables or poor wiring.
Does such a thing exist? Any opinions?
#15344 10/14/02 04:11 PM
Interesting concept, but I suppose there's always the point that each extra level of complexity means something more which could fail to operate as intended. Some other threads here already contain many questions about the longevity of the GFI and AFCI.
Maybe a combined thermal-magnetic and microprocessor controlled breaker would be the ideal, the former acting as a backup, but I can't help feeling that this might be going just a bit too far.
Er, wouldn't it be more like once every five minutes? [Linked Image]
#15345 10/14/02 05:32 PM
C-H, with the marketing buzzword "smart" everything, molded-case breakers may someday allow fault/overload/GF/AF capabilities enabled in firmware at manufacturing.
That would lead, of course, to pirate firmware to “soup up” {or cripple} devices’ “high-performance” features.
#15346 10/15/02 08:30 AM
"The appliance you are using has performed an illegal operation and power to this circuit will be removed. Please remove all appliances, re-install your electrical service, and try again. If the problem persists, please upgrade to Windows AFCI version 34.9"
Sorry.... Couldn't resist adding that one... [Linked Image]
#15347 10/15/02 08:54 AM
And over time your panel will mysteriously fill up and finally crash. Then you'll have to completely take apart the panel and carefully reinstall every component. Then it'll work for some time until the cycle starts once again.
#15348 10/15/02 09:27 AM
oof, what would the spam look like?
let's not go there [Linked Image]
#15349 10/19/02 11:30 PM
Interesting how you can have a micro-processor in a switchboard,does this device take into account the Harmonic component of
our pretty-much common problem of non-linear
loads(computers,VSD's, etc)
