1 members (Admin),
104
11
Posts: 3,674 Likes: 2
Administrator Member
CPSC, Electrolux Home Products Announce Recall of Air Conditioning/Heating Units WASHINGTON, D.C. - The U.S. Consumer Product Safety Commission announces the following recall in voluntary cooperation with the firm below. Consumers should stop using recalled products immediately unless otherwise instructed.
Name of product: Room Air Conditioning and Heating Units
Units: 5,800
Manufacturer/Importer: Electrolux Home Products Inc., of Cleveland, Ohio
Hazard: The heating coil in the units can be damaged during assembly, causing an electrical short and overheating, which poses a fire hazard to consumers.
Incidents/Injuries: Electrolux has received two reports of incidents, though there have been no injuries.
Description: The recalled air conditioning/heating units are installed “thru-the-wall” and include the Frigidaire FAH12EM21 model and Carrier models 52FED31201AA.. The model numbers can be found on a serial plate on the side of the unit. The beige AC/heating units are about 14” high, 24” wide, and 20” in depth.
Sold by: Independent dealer, builders, and remodelers between June 2003 and September 2003 for about $500.
Manufactured in: United States.
Remedy: Consumers should stop using the units immediately and contact Electrolux for a free inspection and repair, if needed.
Consumer Contact: Call Frigidaire toll-free at (866) 335-1754 between 8 a.m. and 5 p.m. ET Monday through Friday. click >> more info
Lostazhell
