Note: 3 Separate Recalls on this page: WASHINGTON, D.C. - In cooperation with the U.S. Consumer Product Safety Commission, (CPSC), Dixon Industries Inc., of Coffeyville Kan., is recalling about 28,000 riding lawn mowers. The fuel tanks on these mowers can crack and leak fuel, posing a fire hazard and risk of burn injuries to consumers.
Dixon has received about 532 reports of fuel leaking from these mowers. There are no reports of injuries or property damage, other than minor lawn damage.
Click >>
more info WASHINGTON, D.C. - In cooperation with the U.S. Consumer Product Safety Commission (CPSC), The Toro Company, of Bloomington, Minn., is voluntarily recalling about 13,000 Toro-brand commercial-grade riding mowers. The riding mower's exhaust system can ignite fuel vapors from spilled fuel if the engine backfires.
Toro has received 10 reports of fires caused when these mowers backfired and ignited nearby fuel vapors. One serious burn injury was reported. Property damage was limited to varying degrees of damage to the mowers
Click >>
more info WASHINGTON, D.C. - In cooperation with the U.S. Consumer Product Safety Commission (CPSC), Exmark Manufacturing, of Beatrice, Neb., is voluntarily recalling about 21,000 Exmark-brand commercial-grade riding mowers. The riding mower's exhaust system can ignite fuel vapors from spilled fuel if the engine backfires.
Exmark has received 15 reports of fires caused when these mowers backfired and ignited nearby fuel vapors. At least one serious burn injury was reported, and two other users reported minor burns. Property damage has varied from minor damage to the machine itself to several thousand dollars damage to other mowing equipment stored nearby
Click >>
more info
