239
36
Posts: 3,672 Likes: 4
Administrator Member
WASHINGTON, D.C. - In cooperation with the U.S. Consumer Product Safety Commission (CPSC), Jade Products Inc., of Commerce, Calif., is voluntarily recalling to repair about 7,200 Dynasty gas ranges. The ranges could tip-over if a heavy weight is placed on an open oven door, posing a risk of burn injuries from hot food or liquids in cooking containers.
Jade Products has not received any reports of incidents. This recall is being conducted to prevent the possibility of injuries.
The Dynasty gas ranges included in this program are all 30, 36, and 48-inch units with the model number DGRSC. The model number is located on the serial plate that is accessed by lifting the right hand cooking module from the range top. The brand name "Dynasty" appears on the front of the range. Click >> more info
