by HotLine1 - 04/23/24 02:17 PM
0 members (), 231 guests, and 11 robots.
djk Offline OP
Just for your browsing:
http://www.esb.ie/esbnetworks/downloads/safe_use_of_electricity.pdf
That's our home (domestic) electricial safety guidelines.
One bit of poor graphic design though which looks like a guy drilling a hole right beside a socket outlet.
It still makes reference to schuko plugs.
[This message has been edited by djk (edited 08-04-2006).]
DON’T ...line the grill pan with cooking foil; the foil could make contact with the live terminals.
I think they might have a hard time convincing people not to do that. Just about everybody uses kitchen foil in the pan at some time or other (myself included).
Do you think that eventually both the R.o.I. and the U.K. will have to relent on this issue?
Do ensure that all fluorescent fittings and metal chandeliers are earthed.
Unearthed light fittings are pretty common here where somebody has put up a new fixture onto a pre-1966 lighting circuit which has no earth.
djk Offline OP
I'm guessing they'll eventually have to allow it. New regs came into force here that are requiring all electrial gear in bathrooms, including lighting, to be RCD protected.
It also seems to have paved the way for sockets... although, seemingly we still have them banned for the timebeing.
Dave,
I'm surprised that the UK and Ireland haven't progressed like the Down-Under countries.
It has been legal here to install socket-outlets with an internal RCD or the option of a switch-board mounted RCD unit for some yearsespecially for lighting circuits in bathrooms.
Since 2000, the latter option is the only one that complies.
Paul,
And what live terminals would that be?
I've repaired a million ovens over the years and I have yet to see some bare live terminals within an oven.
Sure if you were really careless and had foil sticking up all over the place, it could touch the element, which should be at Earth potential.
A lot of the people that write these things just use scare-tactics to warn people.
It is niether effective nor helpful.
I just checked my Neff grill, and you are quite right Mike, there are no live terminals that foil could touch, the elementS terminate in a blanking plate screwed to the oven wall and [presumably] earthed. Are all ovens the same though? Don't forget we have got 'cheap and cheerless' Chinese goods to consider now.
This site is, generally, a very good attempt at making the public aware of electrical hazards, minor criticisms aside, and I found it quite absorbing. Even the 'drill' pic shows the use of a discrete RCD in conjunction, so the worst that could happen is cable damage in the wall, [or is that wooly thinking on my part?]
My 'critique' would be those fireguard pics which are unclear. These should be fixed to the wall in some way to prevent kids pulling them over or crawling round behind them. Surprising how fast tots can find a weak spot in things like this. A moments distraction by a carer and they can get hurt.
K
The live terminals of an oven are in the back compartment away from the cooking area. Theres no way foil from the cooking area could touch live terminals. At worst the foil can touch the earthed sheath of an element.
C-H Offline
Keep in mind that they may have considered old ovens. It wouldn't surprise me if 1950's ovens had live parts inside.
[This message has been edited by C-H (edited 08-07-2006).]
Look,
All a modern cooking element is, is a MIMS cable except it has a Cuprothal element running through the centre of it.
The outer sheath is always at Earth potential for safety reasons.
The same goes for a kettle element, only difference is, a kettle element is nickel-plated.
C-H,
Having live parts inside an oven that early in the sales of appliances would have killed that brand, considering there were no self-cleaning ovens back then.
Most were cleaned by hand at that stage, with a wet cloth.
That's what I had in mind. The only time I've ever seen live terminals (even on a 50-year-old stove) which could be touched by foil was when one of the cover plates was missing, either the one over the end of the grill element or one over the end of the rings on the hob above.
Some of the old portable heating rings with a wire element set in a ceramic base had touchable live parts, both the element itself and the screws at the end, but they were recessed down below the top surface, and that's not the sort of thing you'd be covering with foil anyway.
djk Offline OP
RCDs have been mandatory on socket outlets here since 1980, however it doesn't mean that every house has been rewired since 1980. Many people would have had them optionally installed in the 1970s too, but they weren't compulsary.
However, that being said, it's still not a bad thing to mention the plug-in variety as there are still some installations that predate RCDs.
As for bathrooms, there was no requirement to do anything with lighting except for it to meet certain IP requirements to prevent water ingress and not to be located anywhere near the bath/shower. Also, light switches etc have to go outside or be operated by a pull cord. Basically, you had to design the bathroom in such a way that no electrical gear could be contacted while standing in the bath/shower etc.
The new regulations requring RCD protection on all circuits (lights, fans etc) in bathrooms takes into account the fact that there are fancier light fittings, more over the sink lighting that doesn't simply mean an ugly plastic shaver socket/light, electrically heated towel rails etc etc.
As for putting foil on the grill .. yeah that is a little stupid in my opinion. I have never seen a grill with exposed terminals, in fact, as far as I'm aware having a design like that would violate all of our electrical safety standards. It certainly wouldn't be CE complient.
The major risk with a grill pan covered in foil is fire, not electrocution. There's a serious risk that the grease on the foil can either start smoking very heavily or go up into flames, particularly if you're cooking something rather greasy.
I don't understand why some of these safety edicts continue to persist. Perhaps it was relevant in 1927 [Linked Image]
A more useful message would be please don't stick forks/knives down your toaster's slots!
In Ireland, according to the ETCI safety stats, almost all electrocutions (and there aren't very many) were caused by direct contact with overhead cables or PoCo plant. Most of which occured on farms or construction sites. Accidents involving domestic appliances or wiring seem to be pretty rare. Where accidents have happened in the home, they seem to be mostly due to faulty DIY wiring rather than actual misuse of appliances.
http://www.etci.ie/fatalfacts/index.php?Page=1
(details all electrical fatalities in Ireland over the past few years)
In a population of 4.2 million it's a pretty unlikely way to meet your end to be quite honest.
The only one that comes under the misuse category is where a kid put a nail into the socket of an extension reel. Clearly it either had damaged shuttering / he bypassed the shuttering.
[This message has been edited by djk (edited 08-07-2006).]
