I just found this at
www.handango.com. Do a search for estimating, and then palm os. It is callEstimaker.
I will download it tomorrow and post my comments later.
Here is a description:
EstiMaker is designed to help electrical professionals with the estimating/bidding process, letting an estimator create a take-off estimate in, generally, at least a third of the usual time.
Includes database of over 4600 electrical parts, with pricing and labor data for each part. Just select the parts required for a job, indicate the quantity of each part, enter amount for extras like special equipment and rentals, and EstiMaker will calculate all the factors and create a job estimate.
Create unlimited number of jobs, keep them for future reference or delete them as desired.
Includes Windows companion version that looks and works just like the handheld version. No need to learn two different programs. Learn the handheld version, and you know the Windows version! It shares the handheld version's data files, with 2-way synchronization via the HotSync conduit. Add jobs/make changes on the desktop, HotSync, and the handheld version reflects the changes. Add jobs/make changes on the handheld, HotSync, and the desktop version reflects the changes.
Edit and add to the parts database as needed.
Generates job reports in DOC format (that can be opened/manipulated/printed from any word processor) and exports job reports in CSV format (that can be opened/manipulated/printed from most spreadsheet and database programs).
Beam/Print quick estimate reports in the field, directly from the handheld computer, if you have an IR-capable printer and PalmPrint or SCSPrint software installed in the handheld (free trial copy of SCSPrint included with EstiMaker).
Program setup screen gives the user full control over all the percentages and multipliers used to create estimates, so you can "tinker" with the controls to customize the results and make them match or beat the results you get by your current estimating process. For users outside USA, currency multiplier lets you adjust output for local currency rate changes vs. default U.S. dollar. Once you get EstiMaker to produce estimates that match your old process, you can count on EstiMaker to produce consistent, accurate, and FAST estimates.
Also check out LectriCalc, number one handheld computer calculator for the electrical industry.
Click the [Trial] button above to get the ZIP file download that includes the handheld and windows software as a 10-day free trial. Click the [Add to Cart] button above to get the registration codes that convert the trial version to the unlimited registered version.
If you have a MAC and don't need the Windows software, contact sales@arkansoft.com to get the handheld version file only, in SIT format.
Requirements:Palm OS 3 and up, 460 kb RAM
Compatible Devices/Operating System: Handera 330, Handspring Platinum™, Handspring Prism™, Handspring Treo, Handspring Visor, Handspring Visor Deluxe, Handspring Visor Edge, Handspring Visor Pro, Kyocera Smartphone QCP 6035, Palm III, Palm IIIc, Palm IIIe, Palm IIIx, Palm IIIxe, Palm M100, Palm M105, Palm M125, Palm M130, Palm M500, Palm M505, Palm M515, Palm V, Palm VII, Palm VIIx, Palm Vx, Samsung Smartphone SPH-I300, Sony Clie, TRGpro
