Old Computers?
by gfretwell - 11/21/23 03:45 PM
Simplify MOSFET Test With Source Measure Meter
by gfretwell - 11/18/23 09:20 PM
Ontario Electrical Safety Report
by Admin - 11/02/23 08:56 PM
How are you Jersey folks about the windmills?
by HotLine1 - 11/01/23 07:47 AM
0 members (), 21 guests, and 28 robots.
#13787 09/11/02 08:07 PM
derater Offline OP
Anyone know who has these in duplex s.p.
They have large cross slots at buss end.
#13788 09/11/02 08:45 PM
Clarification - When you say duplex do you mean a breaker with 2 double pole breakers in one or are you talking about tandem breakers?
Anyway, to the best of my knowlege GE does not make a duplex or tandem breaker, instead most of their panels accept half space breakers (THQP series) which can be connect together to make double pole breakers. They do have THQP double pole breakers. I may be wrong or not even answering your question, but that's the best of my knowlege, hope it helps.
[This message has been edited by Electric Eagle (edited 09-11-2002).]
#13789 09/12/02 12:03 AM
GE THQL Breakers and panels are protected from installing too many breakers by design of the half-size "non-CTL" breakers to only be compatible with, say, 20 space panels. Older design GE's aren't compatible at all.
The bus attachment point looks like this: -|-
rather than the single: |
Check the listing on this, but Cutler Hammer and Sq D Homeline make tandems that will fit into a GE bus.
-Virgil
5 Star Inspections
Member IAEI
#13790 09/12/02 05:37 AM
i think T&B makes one to fit 8 panels.....but the 'listings' may be conflicting...... [Linked Image]
#13791 09/12/02 06:08 AM
I have seen the GE 1/2 size breakers and also full size tandems. Wherever you live find a supplier that sells GE products or check Home Depot.
#13792 09/12/02 08:10 PM
If I knew how to create a link, I would; but alas:
Search engine: GE Supply; Power & Distribution
They have a listing of local branches, and an online catalog.
Tools for Electricians
2023 NEC + Exam Prep Study Guides Now Available!
2020 Master Electrician Exam Preparation Combos
2020 NEC Electrician
Exam Prep Combos:
Master / Journeyman
Attic Rat
Attic Rat
Bergen Co.,N.J. USA
Admin 1
313,186 Are you busy
239,129 Re: Forum
222,897 Need opinion
