ShoutChat Box
Can I ask for your input?
by HotLine1 - 01/22/21 01:52 PM
From an outsider- How does tipping work?
by HotLine1 - 01/22/21 01:46 PM
T8 to LED retrofit-ballast or bypass?
by NORCAL - 01/22/21 11:01 AM
Ground fault remover :-)
by NORCAL - 01/16/21 10:29 AM
Photo Editing Software?
by grich - 01/13/21 11:18 AM
Facebook follies, bad wiring
FPE in Germany pt.2
0 registered members (), 22 guests, and 17 spiders.
S. J. Rosch #13144 08/26/02 10:50 AM
Creighton Offline OP
I need a copy of S.J. Rosch "The Current-Carrying Capacity of Rubber Insulated Conductors" Transactions AIEE 1938 p. 155
I tried the IEEE documents section,but they could not come up with it. Can anybody out there help me?
Creighton.
Re: S. J. Rosch #13145 08/26/02 08:21 PM
Bill Addiss Offline
Creighton,
I don't know if this helps any but I found a Standard which references this report:
ANSI/SCTE 32 2001 (PDF file) at the Society of Cable Telecommunications Engineers website: http://www.scte.org/
Maybe they can help locate what you are looking for.
2020 National Electrical Code
Code (NEC)
2020 Master Electrician Exam Preparation Combos
2020 NEC Electrician
Exam Prep Combos:
Master / Journeyman
akmaster
akmaster
alaska
Show All Member Profiles
Trumpy 15
NORCAL 11
274,082 Are you busy
207,865 Re: Forum
195,535 Need opinion
Powered by UBB.threads™ PHP Forum Software 7.7.3
