Shout Box
PurpleAir Recalls Power Supply Units
by Admin. 02/14/19 08:43 PM
Utility Company Programs
by katty81. 02/14/19 11:11 AM
AFDD's coming to the UK
by Trumpy. 02/14/19 12:29 AM
250.104
by BigB. 02/13/19 07:22 PM
Delta Electronics Recalls Solar Inverters
by electech. 02/13/19 10:26 AM
What is this for?
Plug terminals
0 registered members (), 3 guests, and 17 spiders.
240 delta CT #130328
03/09/06 08:14 PM
03/09/06 08:14 PM
Dnkldorf  Offline OP
nowhere usa
Am I right in thinking there is 2 ways to ground the secondary of these if you do not need a nuetral.
I need a 240 transformer for a machine, due to availability I was thinking just get a 480X240 CT.
Now I just could traditionally corner ground the thing, but could I also just bond the XO and pull 4 wires. The 3 phases and EGC from the transformer?
Is one way better than the other if possible?
Dnk..
Re: 240 delta CT #130329
03/10/06 11:26 AM
03/10/06 11:26 AM
X
XtheEdgeX  Offline
Florida
I've always opted to bond the XO and just pull the phases and ground.
Re: 240 delta CT #130330
03/15/06 07:02 AM
03/15/06 07:02 AM
Scott35  Offline
Anaheim, CA. USA
Dnkldorf;
You have got it right, as far as Grounding a Closed or Open Vee Delta Secondary.
Either pick one - ONLY ONE - Line Conductor / Transformer Terminal, and make it the Grounded Conductor,
--or,
Use the Center Tap of "The Center Transformer", and bond it to Ground + Equipment, then bring out an EGC (Equipment Grounding Conductor) from the Transformer to bond the downstream equipment.
Advantage using the Center Tapped method:
Lower Voltage to Ground than with a Corner Grounding Scheme (either 120V to Ground, or 208V to Ground).
Also, if using 1 Phase 2 wire equipment, placing these loads across Lines A and C (assuming Line "B" is the "Top of the Triangle" / "Stinger Leg"), will allow the use of Circuit Breakers with Single Pole Fault Ratings at 120V (the most common breakers).
The Corner Grounded setup would need breakers with single pole fault ratings at 240V minimum - for 1 Phase and 3 Phase connected equipment / loads.
Same goes for 3 Phase loads on the Center Tap Grounded setup.
Advantage for the Corner Grounded setup:
Full sized Grounded Conductor bonded to the entire Ground Bonding scope (star point).
Good luck!
Scott35
2017 Master Electrician Exam Preparation Combos
2017 NEC Electrician
Exam Prep Combos:
Master / Journeyman
akmaster
akmaster
alaska
Show All Member Profiles
Admin 7
andey 3
253,199 Are you busy
189,862 Re: Forum
179,560 Need opinion
Powered by UBB.threads™ PHP Forum Software 7.6.1
(Release build 20180101)
Page Time: 0.021s Queries: 14 (0.004s) Memory: 0.9515 MB (Peak: 1.0773 MB) Zlib enabled. Server Time: 2019-02-16 05:26:31 UTC
