Violation?
by renosteinke - 01/27/23 09:52 PM
Does NEC 551.71 (F) apply to dwellings?
by BigB - 01/20/23 10:46 AM
Power submeter connections
by HotLine1 - 01/19/23 09:09 AM
AFDD's coming to the UK
by Texas_Ranger - 01/17/23 07:22 PM
Burger King crown sillyness
by wa2ise, December 11
240/208 to a house
240/208 to a house
by wa2ise, October 9
1 members (Scott35), 17 guests, and 22 robots.
#129897 11/09/05 11:32 AM
I have an instructor telling me that to do a VD calc, you use the following formula:
VD=(Amps x 1 way Length x R)/1000'
Where R = ohm/kFt from NEC Ch 9, Table 8
It seems to me like you would have to double the length since we are only counting the resistance in one direction...is this correct? I have always used the online calculators, and I'm trying to learn how to do it on paper.
Thanks, Mike
Yup. One way or the other you need to incorporate the round trip distance.
Some equations do this by fudging the resistance values (essentially using the resistance of 2000 feet of conductor, and reporting it as the resistance for 1000 feet 'there and back again')
Others look at the voltage drop on one side only because there is assumed to be no voltage drop in the neutral.
But in all cases there needs to be some consideration of the full circuit.
-Jon
Bob Offline
This would be the correct formula if you are
using a 240 volt 2 wire circuit. There is no return distance required.
If you have a 2 wire 120 volt circuit then you need to count the return distance in the caculation.
Also, you need to use a return distance of the square of three (1.73) for a three phase circuit.
Dolphins Software
Tools for Electricians
2023 NEC Now Available!
2020 Master Electrician Exam Preparation Combos
2020 NEC Electrician
Exam Prep Combos:
Master / Journeyman
Shinnston, WV USA
BigB 9
triple 3
302,542 Are you busy
231,900 Re: Forum
216,535 Need opinion
