Swimming pool pump
by jt7 - 03/31/23 04:13 PM
Using THWN on automotive circuits
by BigB - 03/23/23 11:19 AM
Continuous load
by HotLine1 - 03/08/23 02:11 PM
How's all our Non-US folks doing?
by dsk - 03/08/23 11:56 AM
Old Computers?
by Bill Addiss - 03/04/23 05:06 PM
Burger King crown sillyness
by wa2ise, December 11
240/208 to a house
240/208 to a house
by wa2ise, October 9
0 members (), 119 guests, and 16 robots.
#129329 01/21/05 09:46 PM
Hello there. I am about to use a Universal Motor(a Mototr that can both operate in an AD or DC supply). However i am quite confused by its rating. It is rated at 120 Volts AC. But my supply or source is DC since i am going to use it outdoors. My question is:
Is it safe to use a supply of 120dc?
If not which of these supply can i use?(all in dc)
12 0r 48 volts?
what would be the ideal dc source of it?
will it be 120/sqrt of 2 v dc?
thanks,
Oh Yeah!
There should be a voltage range in the nameplate on the enclosure of the motor or in the manual.
Normally this voltage range is same for AC or DC.For example,24-240,you can applied 24dc or ac,240 dc or ac.Higher voltage applied,more power the motor can output.So you can apply 24dc...48dc...50dc...100dc......to the motor,it depends on your appliance!!
But DO NOT exceed the rated voltage range!!!!
There is a frequency requirement for ac supply,for example 60HZ!!
when applied same voltage to this kind of motor,dc is more effective than ac!!
[This message has been edited by peterpang (edited 01-22-2005).]
No Way!.
splitzapper,
Where are you getting a 120VDC supply from?.
Using a lower than design voltage on a motor will always end in tears, as does a higher voltage.
Personally I'd stick with the AC mains and protect it with a GFCI, if the appliance is going to be used outside.
By the way, what sort of appliance is it?.
Tools for Electricians
2023 NEC Now Available!
2020 Master Electrician Exam Preparation Combos
2020 NEC Electrician
Exam Prep Combos:
Master / Journeyman
TOOL_5150
TOOL_5150
Bay Area
jt7 3
BigB 3
305,254 Are you busy
233,609 Re: Forum
218,258 Need opinion
