196
A family from another country builds a home in America. They bring all their forgien appliances with them, it's all 240v.(or just pick a voltage you'd like here) TV's , radios, blenders, vacuum cleaners, etc. They would like the entire residence to be wired as it would be in their homeland. All common sense aside, is this doable???
I think the sockets and voltage difference you could over come but the Hz could be another matter
hmmmm, that might be a problem, however the dif from 50 to 60 may be negligable given residential appliances. the Q is purely hypothetical, given some interesting threads in this forum. your input especially, Appy I do have customers that spend ridiculous $$$$ on silly things here, so this is not that far out.. I'm wondering how the AHJ would view a home with a different voltage system than normally seen...
Posts: 3,682 Likes: 3
Administrator Member
Sparky, As coincidence would have it, here comes a question from todays' Mailbag: Dear Sirs, We are emigrating from the UK to South Carolina and have many electrical items we want to take with us - some for sentimental reasons. We use 220/240v here. Will it be possible to use our items? Will we need to install a generator? Advice please. Sincerely Leonie leonie.jarrett@virgin.net
Posts: 4,116 Likes: 4
Sparky, I hope that you don't mind if I borrow your thread a little here? (I'll fill up the tank for you) Now, in our 'Real Life' situation here Leonie doesn't say if they'll be going to a new Home being built or an existing Home. So it may not be exactly the same question as yours. I've invited Leonie to participate, so maybe We can fine-tune things here if necessary to meet the situation. I think there are 2 things to consider here and they should be separated right away for a mimimum of confusion. Since you started discussion on the wiring of the houes, let this be the 'Practical' How-do-you? and Can-you-do-it? I started a separate Thread on the specific effects that different voltages and frequencies might have on Electrical items. That is at: https://www.electrical-contractor.net/ubb/Forum7/HTML/000020.html Bill
Hi Leonie! this is an oppourtune coincidence, please jump on in here. We have a 240/120v system here. we do supply 240 to dryers, ranges,hot h2o, and other such appliances, so to do so for your items may be possible. One Q that comes to mind would be if dedicated circuits were to be introduced, would it be better to correct cord cap and matching recptacles to an American version, or purchase a UK receptacle. ( I have an "unstumpable" supplier that would love this!) [This message has been edited by sparky (edited 03-25-2001).]
Sparky, According to that Resource We were looking at recently this is the type of Plug they use
I think some of these UK male cord caps are fused ?? Is this true? I will put word out as to availability of mating receptacles [This message has been edited by sparky (edited 03-25-2001).]
Yep thats right Sparky they have little fast blows in the male ends also the sockets on the wall as they RingMain in the UK
As a side note, there was also information that said that receptacles were typically controlled by an adjacent switch.
