Shout Box
AFDD's coming to the UK
by Texas_Ranger. 02/18/19 02:04 PM
Israel
by Texas_Ranger. 02/18/19 02:01 PM
250.104
by gfretwell. 02/16/19 01:08 PM
PurpleAir Recalls Power Supply Units
by Admin. 02/14/19 08:43 PM
Utility Company Programs
by katty81. 02/14/19 11:11 AM
What is this for?
Plug terminals
1 registered members (gfretwell), 10 guests, and 28 spiders.
Condo Owner NM Installation #122051
09/16/05 03:00 PM
09/16/05 03:00 PM
Admin  Offline
NY, USA
I Opened this panel and found these white and black conductors landed to the same 20 Amp single pole breaker and the bare ground on the neutral buss carrying the neutral current, no connector in the panel, cable run downstairs into the garage where I am sure there is a concealed splice in the wall before it exists in 500 Wiremold, through the wall of the garage with the wall paper with no raceway to quad receptacles in an office. Lucky for the new condo owner it is still under warranty,
Mark
(techgod)
Re: Condo Owner NM Installation #122052
09/16/05 05:13 PM
09/16/05 05:13 PM
BElder  Offline
Paradise, CA. U.S.A.
A backup conductor incase one fails [Linked Image] also with 2 12 Ga. conductors that could be a 40 amp. circuit [Linked Image]
& they could have done alot nicer job of drywall texture in that panel too [Linked Image]
Re: Condo Owner NM Installation #122053
09/16/05 08:51 PM
09/16/05 08:51 PM
sandsnow  Offline
Irvine, CA, USA
Nice offset on the wiremold, though.
Larry LeVoir
Inspector
City of Irvine, CA
2017 Master Electrician Exam Preparation Combos
2017 NEC Electrician
Exam Prep Combos:
Master / Journeyman
Show All Member Profiles
Admin 7
253,245 Are you busy
189,886 Re: Forum
179,597 Need opinion
Powered by UBB.threads™ PHP Forum Software 7.6.1
(Release build 20180101)
Page Time: 0.014s Queries: 14 (0.003s) Memory: 0.9522 MB (Peak: 1.0752 MB) Zlib enabled. Server Time: 2019-02-19 07:13:57 UTC
