Any women electricians here?
by HotLine1 - 01/27/22 02:44 PM
12 Lead Motor Connection Weird
by emolatur - 01/19/22 02:40 PM
Well There's your problem.
by gfretwell - 01/08/22 12:17 AM
Happy New Year!!
by HotLine1 - 01/04/22 09:50 AM
Sangamo s309.2
by Robski - 12/31/21 04:54 PM
240/208 to a house
240/208 to a house
by wa2ise, October 9
Now you know.
Now you know.
by Tom_Horne, September 7
0 members (), 50 guests, and 14 robots.
#121163 06/20/05 03:16 PM
(submitted via Joe Tedesco)
Recieved call rooftop heating&cooling unit not functioning. Upon inspection found somewhat of a problem. Brand new unit, old disconnect manually closing switch would not work. Actually had to close knife blades with insulated handles of linemans pliers.
#121164 06/20/05 06:43 PM
e57 Offline
Whats right? It's off!
#121165 06/20/05 07:32 PM
What's right here?.
Well, the Phase Sequence in the top pic looks to be OK. [Linked Image]
Not a lot else, though.
I see in the bottom pic that this unit has been "modified" since it left the factory, hence the loose Ground wire.
Unbelievable. [Linked Image]
#121166 06/20/05 07:36 PM
I certainly hope you don't mean that you energized this.
#121167 06/21/05 06:56 PM
Mike,
Take off your Commonwealth thinking cap and put on your American one instead...... [Linked Image]
#121168 06/21/05 07:56 PM
What's right.. hmm.. they used wirenuts.. beyond that, it looks pretty hopeless..
lots wrong with it..
poor workmanship
romex
lack of chase nipple/bushing
lack of connector on flex
improper phase color (assuming 3 phase)
improper phase sequence
improper grounding
inoperative equipment
improperly sized wiring?
did I mention the poor workmanship?
#121169 06/22/05 01:06 PM
Too bad the black wire wasn't blue, it would have made pic #1 look so much more patriotic (especially when the fireworks start).
I especially like the way the installer so conscientiously left the romex EGC wrapped in paper (pic #3), so it wouldn't "short" to the box.
On a slightly more serious note... judging from pic #4, is this really 3-phase equipment? The white wire wanders out of the picture, unlike the black and red, which are spliced to the unit primary, so maybe it's really a neutral? If so, why the 3-pole disconnect?
#121170 06/26/05 12:24 PM
this looks suspiciosly like one of the local HVAC contractors work -- they always alter the equipment to make it work better :eek
Tools for Electricians
2020 Master Electrician Exam Preparation Combos
2020 NEC Electrician
Exam Prep Combos:
Master / Journeyman
MarkC10
MarkC10
CA, Inland Empire
288,257 Are you busy
220,326 Re: Forum
206,314 Need opinion
