227
13
Posts: 3,682 Likes: 3
Administrator Member
(submitted via Joe Tedesco) What is probably more interesting is that this pedestal is not for the room enclosure that it is in, it is for the adjoining unit. This was the result of the owner splitting most of the manufactured home spaces into two RV spaces and then allowing the larger Park Model homes to be set and awnings constructed. This scenario is replicated along an entire row of homes, and seven were found to have been enclosed in illegal room additions.
- codeenforcementguy [This message has been edited by Webmaster (edited 04-13-2005).]
Now there's a new twist to stealing electricity...you hide the meter so that the POCO cannot find it! Mike (mamills)
That's a good point. Does the PoCo actually have to open this and climb in to read the meter?
RSlater, RSmike
Hard to tell from that pic, but since the meter appears to be in a plastic opaque housing, it may be electronic and read remotely by "CellNet" or RF.....
Which would explain why the POCO hasn't shut them down, if you tried to bury a conventional meter like that around here, our POCO would shut it down.
Stupid should be painful.
Posts: 943 Likes: 2
Being that it is in a trailer park,are the spaces submetered?
This will be taken care of soon. It is tornado season after all.
Check out the lighting circuit in the upper right hand corner. A handy box with a twisted KO, some lamp cord and a switch. Shocking!
SD
SD It is best for a leader to be both feared and loved. But since this usually cannot be done, it is safer to be feared.
