Strobing LEDs
by Bill Addiss - 10/06/22 07:33 PM
How's Florida doing with Hurricane Ian?
by Bill Addiss - 09/28/22 12:41 PM
Tough being a lineman's kid
by Bill Addiss - 09/28/22 12:39 PM
GFCI's pops in large numbers
by dsk - 09/26/22 04:35 AM
AFCI’s Revisited
by sparky - 09/24/22 09:58 AM
240/208 to a house
240/208 to a house
by wa2ise, October 9
Now you know.
Now you know.
by Tom_Horne, September 7
2 members (Scott35, Bill Addiss), 17 guests, and 12 robots.
#118530 10/05/04 09:21 PM
These pictures were taken at what should have been a framing inspection.
There was not supposed to be any electrical work done under the permit, which was issued for a kitchen remodel. BTW all this was live at the time.
-Todd
#118531 10/05/04 11:18 PM
Isn't duct tape the greatest? Maybe the outlet and light were left open for your rough inspection, though as a rule I feel I get more favorable inspections if I don't electrocute the inspector.
Dave
#118532 10/06/04 08:00 AM
(2nd pic)
I don't think that they had this in mind when they said that the white conductor could be used as a hot to the line side of a switch.
Unless you count the pull chain as the switch [Linked Image]
#118533 10/06/04 09:03 AM
Just a little question,
Is it legal to have one wire colour of wire going into a wirenut and another leaving it?.
Sure in the second pic, that's in a box behind a light fitting, but.....hmmm.
#118534 10/06/04 02:09 PM
If you trace the leads back you will find that the fixture is only connected to the white conductors of the romex in the box. And yes, it did light up when the pull switch was operated.
#118535 10/06/04 06:11 PM
The "keyless" in pic #2 is a little more appealing than the crud in pic #3.
I'm curious if it was turned down or if the homeowners are facing any kind of legal recourse now for this.
#118536 10/07/04 07:31 AM
In addition to the obvious violations the owner had far exceeded the limits of his permit. A stop work order was issued until qualified contrators were brought in.
Tools for Electricians
2023 NEC Now Available!
2020 Master Electrician Exam Preparation Combos
2020 NEC Electrician
Exam Prep Combos:
Master / Journeyman
Grover
Grover
Sebago, ME, USA
dsk 3
297,801 Are you busy
228,533 Re: Forum
213,360 Need opinion
