Elk’s Lodge 11th hour ritual chime clock
by gfretwell - 10/01/23 02:06 AM
One breaker only works when the dryer is running
by gfretwell - 09/28/23 06:40 PM
Strange breaker tip problem
by gfretwell - 09/25/23 08:13 PM
An impossible Support Violation
by gfretwell - 09/12/23 04:29 PM
How are you Jersey folks about the windmills?
by gfretwell - 09/08/23 02:21 PM
0 members (), 18 guests, and 15 robots.
#115517 11/08/03 12:58 AM
This is a 200A OH service, there is a visible violation, with a rusty noodle in the panel due to it, probably old hat to the ECN crew and those whom do 'dripping' panel' service calls...
~Steve aka sparky~
#115518 11/08/03 07:52 AM
Certainly a violation of 230.54 (C). A better drip loop would also fix the problem.(The violation would remain however) Also the weatherhead should not be angled like that.
[This message has been edited by Electricmanscott (edited 11-08-2003).]
#115519 11/09/03 06:35 AM
I've taken to stuffing my weatherheads with dux seal in the last few years, as a hedge to noodlitis....
#115520 11/10/03 12:04 AM
Sparky,
Just curious here, in the Meter enclosures you use now is the Neutral connection in the middle?
The reason I ask is the ones we use now for the last couple of years have the Neutral connection moved to the left side and out of the central 'drip-zone'
Tools for Electricians
2023 NEC + Exam Prep Study Guides Now Available!
2020 Master Electrician Exam Preparation Combos
2020 NEC Electrician
Exam Prep Combos:
Master / Journeyman
AllClear
AllClear
Belmond Iowa US
lemahj 3
311,321 Are you busy
237,644 Re: Forum
221,406 Need opinion
