1 members (Scott35), 489 guests, and 7 robots.
#115323 10/17/03 01:04 PM
This is marked "MADE IN HOLLAND."
I found it while digging in my back yard during the summer. Were these (are these) used often?
-ThinkGood
TG:
Nice find....I had a few of these around somewhere that were removed during a renovation job. They are "wirenuts", and were used as such a long time ago, before plastic. I never noticed that they are from Holland. Wonder what they cost???
I have an old electric menorah from which I removed an ill-fitting white ceramic wirenut to replace it with a better fitting but garish yellow plastic one.
Some people also call them "marrettes".
The one I removed, however, is unglazed. There is also no metal spring inside the porcelaine shell and no maker's mark -- just a UL logo on the top.
I saw, years ago, some tiny ceramic wire nuts in a lighting store here in New York. Didn't know they still made them in that material.
While talking about old splice caps here, I just removed an old one from a 40's house. It was a brass? crimp on the wires. UL listed for 10-18 AWG wires. There were 4 dents (one on each side) so I guess it was sort of crumpled on the wires with a special tool. Over this was a black rubber cover shaped like a wirenut.There were 4 bumps (to fit in the dents?) inside. At the end was a B in a triangle (Buchanan, I think) and the number 2005. As an extra security for the insulator, there was a red ring slid over the cap. I think it was original. I has to cut the crimp off though, so I was left with some 4" leads from the box. [Linked Image] Very labor intensive.
Thinkgood, is there a spring inside? I guess even if there was, it has rusted out from being buried for years.
Those crimp splices are not necessarily old. You can buy them all over the place. Home depot even sells them (though they don't sell the necessary crimping tool)
See:
Ideal/Buchanan crimp connectors
-Jon
[This message has been edited by winnie (edited 10-17-2003).]
I use Ideal crimps all the time on grounds. I just thought it was neat the way things were done before wire nuts were commom.
ps I use a klein 1005 crimper
Should this be in the 'Nostalgia' area?
Can anyone date the usage of these?
Porcelain wire nuts are still used and readily available. They are for areas of high heat(stoves,ovens,...). No spring, just threaded cone.
Steve
U
Another case of one brand's name becoming the accepted name of a generic product. Maybe its just a Canadian thing?
http://tnbelectricalworld.tnb.com/contractor/docs/marrette.pdf
Not just Canadian (maybe for marrettes "though"). Other countries often use tradenames for the generic name of a product.
