Photos of the Week:
Avalon Theatre
Avalon Theatre-1 2 3 4
0 members (), 55 guests, and 19 robots.
#115187 08/23/03 04:14 PM
Says I can't pick on him anymore for all the extension cords in his garage. He moved.
Says the new garage is all wired in conduit, and the ex-owner really knew his stuff!
...S
(electure) [Linked Image]
#115188 08/23/03 05:44 PM
Wow, FMC cord caps, much better than extension cords. [Linked Image]
#115189 08/23/03 05:52 PM
From the looks of the meter ring somebody had tampered with the meter in the past, and in regards to working space somebody got Rheemed.
PIC #2 YUCK!
#115190 08/23/03 06:26 PM
Hello electure, nice pictures.
Perhaps I shouldn't write this but...the reflection of you in picture #1 reminds me of an e-mail I got with a guy trying to sell a tea-kettle on E-bay. It was a chrome kettle and reflected him taking the picture. The bad part is the guy was 250 pounds+ and totally nude!!!
Ryan Jackson,
Salt Lake City
#115191 08/23/03 06:44 PM
[Linked Image from click-smilies.de]
#115192 08/23/03 06:48 PM
Ryan,
Too much information there, really ...
#115193 08/23/03 06:55 PM
Did you buy the kettle?
#115194 08/24/03 07:31 AM
Ooops, well at least I was dressed for the "photo shoot".
Something that you're not able to see in the picture is that all the EMT fittings used are of the set-screw type.
That meter ring is of a tamper-proof design.
The work (damage) was done without a permit long before it was installed....S
[This message has been edited by electure (edited 08-24-2003).]
#115195 08/25/03 10:06 AM
Is that a raingutter downspout, or...? It appears to have some sort of piping entering it below the recp, and some kind of wires sneaking out from under it next to the panel.
The open box for the missing porchlight is good too, lol. [Linked Image]
#115196 08/25/03 03:33 PM
Central air systems that were retrofitted often use downspouts to route the freon pipes from the compressor to the cooler units inside the house, usually in the attic. They may pass low voltage control wiring that way too. I doubt that the code would permit power cables, though. Downspouts look prettier than exposed pipes, and offers some physical protection to those pipes as well.
As for the second picture, I think that there is a common mis preception amoung the public that materials listed for use in house wiring would also more than qualify for use for making extension cord sets. As if the requirements for anything that plugs into a wall socket are less stringent than for wiring installed inside the walls of a house.
As Joe T. points out in that picture of him holding a homemade extension cord at a hotel conference, that's not true. A metal box intended for house wiring isn't designed to be tossed about like an extension cord is likely to see. The knockouts getting dented in, for example. Also the constant flex the cord applies to the clamps on the box will make them loose. This doesn't happen inside walls with house wiring. The requirements are different, not less stringent.
Tools for Electricians
2023 NEC + Exam Prep Study Guides Now Available!
RH1
RH1
California
BigB 2
353,524 Are you busy
277,362 Re: Forum
256,299 Need opinion
