by ale348 - 03/29/24 01:09 AM
by NORCAL - 03/19/24 05:11 PM
The gfci for the pool light is via a receptacle at the pool equipment.No gfci protection for the pump.The bare grounds are connected to the neutral bar.The blue is actually phasing tape that it appears someone used to identify the white as a phase conductor.
How about the service entrance ?conductors.The rigid nipple from the meter can is about 2 inches too short.
Donnie
It looks sort of like a Home Depot display !!
The bare wires are pretty scary, But what is that black rectangle in the bottom of the panel. It looks like a radio shack transformer. Could it possibly be for low voltage wiring? If so how are the wires attached to the plug? It looks like there are two wires that are electrical taped onto the plugs.
scotts,
That's a surge suppressor laying in the bottom of the panel.It's goes to 2 single pole 20 amp breakers.Flush mount panel,guess the installer was at a loss as to where to install it.
Donnie
