Al Hildenbrand - Minneapolis - obituary
by bcpappas - 02/02/23 08:01 PM
Violation?
by renosteinke - 01/27/23 09:52 PM
Does NEC 551.71 (F) apply to dwellings?
by BigB - 01/20/23 10:46 AM
Power submeter connections
by HotLine1 - 01/19/23 09:09 AM
Burger King crown sillyness
by wa2ise, December 11
240/208 to a house
240/208 to a house
by wa2ise, October 9
0 members (), 20 guests, and 15 robots.
#11345 07/10/02 07:17 PM
ayrton Offline OP
I am pricing out a fire alarm system for a sprinklered building. Where can I find out the info needed for the requirements?
#11346 07/10/02 07:53 PM
Ron Offline
Your applicable building code and NFPA 72.
Many local fire alarm vendors will lay one out for you.
Ron
#11347 07/11/02 10:02 PM
ayrton,
If your company isn't certified to install fire alarm, I would sub it out to someone who is certified. Your company can install all the conduit stubs in the walls for the "pulls", "strobes", "audio/visual strobes", boxes for the "smokes", etc. Good luck.
Earth, Wind, and Fire Alarms,
Doc
The Watt Doctor
Altura Cogen
Channelview, TX
#11348 07/13/02 04:45 PM
Good advice from the doctor!
This is standard procedure for us for commercial construction. The only time I'll touch any F/A equipment is if it's something really simple like moving a smoke or pull-station.
GJ
Additional benefit is that you will know your exact cost going for F/A for bidding.
[This message has been edited by golf junkie (edited 07-13-2002).]
#11349 07/14/02 08:23 AM
F
That is exactly what we do. In the area where I live, Simplex Fire Alarm Company is used quite a bit. All of their Technicians are certified.
Tools for Electricians
2023 NEC Now Available!
2020 Master Electrician Exam Preparation Combos
2020 NEC Electrician
Exam Prep Combos:
Master / Journeyman
HCE727
HCE727
Delaware County, PA, USA
BigB 4
303,010 Are you busy
232,039 Re: Forum
216,773 Need opinion
