#109716 11/24/05 09:50 PM
Trumpy Offline OP
Pictures submitted by Sierra Electrician :
The photo 100A W/H, is a Single Phase, 240V, 4500W Heater fed via a 100A Fused Circuit. I guess they won't have to worry about tripping the circuit in a fault situation.
The photo Nice Connection, is a cool violation photo.
Thanks Rob!. [Linked Image]
{Message edited to fix up a few things.}
[This message has been edited by Trumpy (edited 11-25-2005).]
#109717 11/25/05 04:46 PM
If upstream from the disconnect the water heater is protected by the proper ocpd (ie. the feeding panel or gear), then there's no problem...
On the otherhand, the deep P-Ring looks a bit suspect being nailed to the plywood.... Not to mention the grounding bar that appears to not-so-firmly be attached to the above can....
#109718 11/25/05 05:29 PM
1. The W/H is protected by a 100A 3P breaker in the sub panel...the 100A 3P Fused disconect and (2) #4 THWN to the heater itself.
2. The 2" Plaster Ring is not intended for this use and is screwed to the plywood. This is a circuit for a bailer in a different area of the bldg.
These were found at an old Wal-Mart in Bakersfield,CA
#109719 11/25/05 08:54 PM
Trumpy Offline OP
Ahh Rob,
Now the penny has dropped, it was you that sent me the pics.
Just a little note to you guys that send us Mods pictures.
Could you please give your ECN Username as well, I don't know all of you guys' email addresses.
Hence the attributing the pics to Robert.
Not a big thing but it does save a bit of confusion.
#109720 11/25/05 09:53 PM
But...Trumpy.. I thought we knew each other better than that.
#109721 11/26/05 12:29 AM
Let me guess..... White Lane?
#109722 11/26/05 12:50 AM
Calloway & Rosedale
It wil be a Smart & Final soon.
[This message has been edited by sierra electrician (edited 11-25-2005).]
#109723 11/26/05 01:59 AM
Calloway & Rosedale?? You mean the old Save-Mart behind the Chevron? You're working literally about a mile from my house [Linked Image] The closest Wal Mart (Rosedale & Coffee) was alive and kicking to ungodly proportions today [Linked Image] [Linked Image]
Randy
#109724 11/26/05 02:11 AM
I was told it was a Wal Mart. my mistake
#109725 11/29/05 08:41 PM
Y
Sierra Electrician, I trust you are using the term "protected" loosely! [Linked Image]
