1,299
13
Posts: 3,672 Likes: 4
Administrator Member
I just spoke to my friends Bill and Al. Bill is quite proud to have such fine work done in a town named after him, and Al points out that "there is no controlling legal authority."
Wow. The scary thing is that there are probably dozens, if not hundreds, of large holiday lighting schemes that may also be set up like this.
It's really shocking (pardon the pun) that people still don't understand that 110 is dangerous, be it a shock hazard or fire hazard, or both.
Heh, wow, ten plugs into an extension cord... at my house 3 is a max... I think the lights say you can only plug X number together safely...
Maybe the ambient temperature helps.
Has anyone ever read 527.2(A) or 305-2(a) ?
Glenn
OK, so much for the OSHA prohibition of using NM cable as an extension-cord substitute. And forget not using live vegetation to support wiring.
They used to say that rainwater was less conductive than tap water for its 'purity.' Would that extend to muddy snow?
Maybe mass-ganged cord caps with snow derating are really safer than a stack of those 'extry outlet' air fresheners.
UL has a fairly good presence in a lot of countries that make 'export' electrical goods. I wonder if they ever anticipated this mode of operation?
[This message has been edited by Bjarney (edited 07-17-2002).]
Posts: 7,413 Likes: 9
Wow: If there was ever a installation that deserved an "award"! Went to the linked site...... Nice to see that there are some bubble covers Also, in the pic with the 4x4, are those light strings across the road??? As I don't see any controls, I guess some brave guy turns it on at the panels?
HotLine1 John
I have seen an exact replica of this back in '98. It was at the local tech college I was attending to learn... you guessed it... the NEC. We would chuckle every time we walked outside for a break.
Posts: 8,450 Likes: 4
Who the hell done this work?, They need to be taken to task for the lack of mechanical protection. What sort of wire is used there?, it looks like single core TPS, with all them wires, I may be wrong. But, just because it is a temporary installation, doesn't mean it should be done slack, like this one. The use of multiple power connectors, worries me,especially used outside.
You guys keep your cameras out of my yard!
scott, couldn't be your yard?could it. ![[Linked Image]](https://www.electrical-contractor.net/ubb/biggrin.gif)
