#107323 10/05/04 09:31 PM
Photos by Dave55:
#107324 10/05/04 10:36 PM
aww... you should have taken some "before" pictures too
#107325 10/05/04 11:10 PM
This IS the "before" pictures!!! Can't you tell that crack in the second picture needs to be caulked?
This is a very typical service in my neighborhood. The vertical conduit ran through a concrete pad. When the pad settled it pulled the conduit out of the meter socket. I did a service across the street last year that had done the same thing.
The distribution panel is a Federal Pacific. The electrical contractor saved where he could, as breakers were available at the time.
This was a pretty good job except the commute was a killer (90 seconds).
I was going to post some "after" pictures, but I'm not sure I want the vultures picking on my bones.
Dave
#107326 10/06/04 07:51 AM
Hi Dave,
What's the white wire coming from the top right switch down to the neutral bar for?? (4th picture). [Linked Image]
#107327 10/06/04 09:10 AM
That's not a neutral for a GFCI is it,
Electure?.
Just a wild guess.
#107328 10/06/04 08:01 PM
That's two different wires, guys. It does look like one, but they must cross on the right to look like one. The upper connection was a 240 volt circuit for the clothes dryer.
Dave
#107329 10/07/04 01:43 AM
The pipes pill out of the meters around here too. They say with groung freezing things can move around a bit. Plus not compacting the soil. We take those uot and put in a underground pedistal.
Besides the meter did you pass your inspection Dave? Doesent anything pass in Crystal Lake?
#107330 10/08/04 12:11 AM
2 more from Dave:
#107331 10/08/04 04:11 AM
e57 Offline
Is that a new idea on phase id? Black, black, black, black, black, black, red, red.
#107332 10/08/04 06:47 AM
My work passes everywhere,Tom, doesn't yours? The colors are the different wire guages.
Dave
