GFCI's pops in large numbers
by dsk - 09/26/22 04:35 AM
AFCI’s Revisited
by sparky - 09/24/22 09:58 AM
NFPA Price Increase Coming
by Bill Addiss - 09/23/22 02:22 PM
Siemens breakers
by gfretwell - 09/23/22 01:45 PM
What do you look like?II
by HotLine1 - 09/22/22 12:33 PM
240/208 to a house
240/208 to a house
by wa2ise, October 9
Now you know.
Now you know.
by Tom_Horne, September 7
1 members (dsk), 10 guests, and 11 robots.
#106724 02/22/05 11:44 PM
Car wash equipment in a wet location needs to be replaced.
(Joe Tedesco)
2020 NEC & Related Reference & Study Guides
Pass Your Exam the FIRST TIME with these Exam Prep Combos:
>> Master Electrician Exam Prep     >> JourneyMan Electrician Exam Prep
#106725 02/23/05 06:09 AM
Joe,
Is that the Dryer motor that feeds hot air into the wash area?
#106726 02/23/05 07:32 AM
Yes. The gas station service was being upgraded and most of the equipment in the car was was in need of repair or replacement.
#106727 02/23/05 08:29 AM
Was the equipment working?? Doesn't need to be replaced then [Linked Image] Worked on several car washes for many years. Has to be one of the worst enviroments on anything not Stainless steel. I was always amazed that they expect relays, terminals, starters and other electrical stuff to work anywhere in the tunnel. In Maine, people wash their cars when the temps are below zero, you can't see from side of the tunnel to the other from the water turning to fog(going thru dew point). That fog is full of very corrosive chemicals found in the soap. Gets on and in everything.
#106728 02/23/05 07:34 PM
Interesting to note that the motor is not a TEFC (Totally Enclosed Fan Cooled) type. I would think the windings would have shorted out from the moisture...
Stupid should be painful.
Tools for Electricians
2020 Master Electrician Exam Preparation Combos
2020 NEC Electrician
Exam Prep Combos:
Master / Journeyman
watersparkfalls
watersparkfalls
Washington...Not DC
Trumpy 4
dsk 4
297,374 Are you busy
228,245 Re: Forum
213,147 Need opinion
