GFCI's pops in large numbers
by dsk - 09/26/22 04:35 AM
AFCI’s Revisited
by sparky - 09/24/22 09:58 AM
NFPA Price Increase Coming
by Bill Addiss - 09/23/22 02:22 PM
Siemens breakers
by gfretwell - 09/23/22 01:45 PM
What do you look like?II
by HotLine1 - 09/22/22 12:33 PM
240/208 to a house
240/208 to a house
by wa2ise, October 9
Now you know.
Now you know.
by Tom_Horne, September 7
0 members (), 16 guests, and 19 robots.
(submitted via Joe Tedesco)
What is probably more interesting is that this pedestal is not for the room enclosure that it is in, it is for the adjoining unit. This was the result of the owner splitting most of the manufactured home spaces into two RV spaces and then allowing the larger Park Model homes to be set and awnings constructed. This scenario is replicated along an entire row of homes, and seven were found to have been enclosed in illegal room additions.
- codeenforcementguy
[This message has been edited by Webmaster (edited 04-13-2005).]
2020 NEC & Related Reference & Study Guides
Pass Your Exam the FIRST TIME with these Exam Prep Combos:
>> Master Electrician Exam Prep     >> JourneyMan Electrician Exam Prep
Now there's a new twist to stealing electricity...you hide the meter so that the POCO cannot find it! [Linked Image]
That's a good point. Does the PoCo actually have to open this and climb in to read the meter?
RSlater,
RSmike
Hard to tell from that pic, but since the meter appears to be in a plastic opaque housing, it may be electronic and read remotely by "CellNet" or RF.....
Which would explain why the POCO hasn't shut them down, if you tried to bury a conventional meter like that around here, our POCO would shut it down.
Stupid should be painful.
Being that it is in a trailer park,are the spaces submetered?
This will be taken care of soon. It is tornado season after all.
Check out the lighting circuit in the upper right hand corner. A handy box with a twisted KO, some lamp cord and a switch. Shocking!
SD
SD
It is best for a leader to be both feared and loved. But since this usually cannot be done, it is safer to be feared.
Tools for Electricians
2020 Master Electrician Exam Preparation Combos
2020 NEC Electrician
Exam Prep Combos:
Master / Journeyman
Trumpy 4
297,386 Are you busy
228,252 Re: Forum
213,152 Need opinion
