ShoutChat Box
Tinfoil-hat crowd is getting stupider...
by grich - 05/28/20 01:38 PM
Norwegian power?
by WaterIngress - 05/27/20 11:43 AM
Tips on how to read 2018 CE Code Book?
by Rob2019 - 05/23/20 10:02 AM
Pool Lights?
by gfretwell - 05/21/20 02:03 PM
T rating of a switch
by geoff in UK - 05/17/20 03:13 PM
Facebook follies, bad wiring
FPE in Germany pt.2
1 registered members (Scott35), 79 guests, and 7 spiders.
Stair Closet Light #106233 05/16/05 02:26 PM
This pic shows one of my favorite lighting solutions.
Using a receptacle conveniently located on the wall of the stairwell, someone first plugged in a switch- a device that was once often seen. From this they ran a cord/plug assembly (probably from an old appliance), made a "flying splice" to a piece of romex, ran that through a hole in a stair riser, and on to a surface-mounted keyless in the under-stair closet.
- renosteinke
2017 / 2014 NEC & Related Books and Study Guides
Re: Stair Closet Light #106234 05/18/05 08:30 PM
BigJohn Offline
What a strange place for a receptacle to be located....
"This looks like a good spot for a floor lamp!"
-John
Re: Stair Closet Light #106235 05/20/05 11:21 AM
SvenNYC Offline
Is that using one of those little plug-in switches?
They're a common item in the dollar stores around here.
Yah, that is a weird spot for a socket. Wonder what was there initially.
Re: Stair Closet Light #106236 05/20/05 09:51 PM
renosteinke Offline
Yes, one of those plug-in switches.
2020 National Electrical Code
Code (NEC)
2017 Master Electrician Exam Preparation Combos
2017 NEC Electrician
Exam Prep Combos:
Master / Journeyman
pcsailor
pcsailor
Minneapolis, MN, USA
Show All Member Profiles
Trumpy 7
266,109 Are you busy
200,961 Re: Forum
189,658 Need opinion
Powered by UBB.threads™ PHP Forum Software 7.7.3
