228
Posts: 3,682 Likes: 3
Administrator Member
I was a little disappointed to see that NEC 358.24 only says that bends "be made so that the tubing is not damaged." I suppose, though, that the further specification that the radius "shall not be less..." could apply to finding a violation to the sort of free-hand bending as is shown in this photo. Why spend $8 for a bender, when you can tweak the pipe between studs, bricks, or a handy bumper? :-(
- renosteinke
Reno, I do think the tubing is damaged. Aah, maybe I'm just picky
Does it make the electrical installation unsafe if the tubing remains undamaged?
Ryan Jackson, Salt Lake City
No Ryan, but if I installed the pipe in the pic, I would certainly hope nobody ever found out who did it.
I think this might fail the "workman-like" test. I confess that I've improved the angle of a conduit over my knee several degrees occasionally when deep in an attic or crawl-space.
Dave
I suspect that one of the bends made is too small in radius to comply with code...and the EMT almost certainly has a "flat spot-" even if this guy stopped just short of a kink.
With workmanship like this, no one should be surprised to see that the EMT is completely unsupported, or to find #12 wires serving a 30 amp water heater (yes, he did that also.) And, of course, no ground wire- even though there is flex used.
no one should be surprised to see that the EMT is completely unsupported, or to find #12 wires serving a 30 amp water heater That sounds OK... if he used 2 per leg Of course, about the grounding wire... if the flex is under 6', is is required? [This message has been edited by DougW (edited 04-06-2005).]
Good catch, Doug....that is one of our local requirements: all flex, sealtite get a ground wire.
WM, 110.12 issue there too. Looks like a 90 with 2 kicks, a twist, and a curl. Unbelievable.
ed
