EMC Glands on Motors
by Trumpy - 12/01/22 06:12 AM
Ground Rods: Installation and Hook-Up
by Trumpy - 12/01/22 05:54 AM
Happy Thanksgiving all!
by gfretwell - 11/30/22 05:55 PM
Colt Firearms Switchbox
by NORCAL - 11/29/22 01:04 AM
Perfect work light?
by gfretwell - 11/22/22 12:48 AM
240/208 to a house
240/208 to a house
by wa2ise, October 9
Now you know.
Now you know.
by Tom_Horne, September 7
0 members (), 30 guests, and 11 robots.
This picture was taken exactly as I discovered it. Notice the screw-in outlet in the center of the porcelain lampholder. The brown cord has a female cord cap on the end with a cheater plugged into it!
Photo by: Ed Corcoran
2020 NEC & Related Reference & Study Guides
Pass Your Exam the FIRST TIME with these Exam Prep Combos:
>> Master Electrician Exam Prep     >> JourneyMan Electrician Exam Prep
Using an old book (sorry...).
Art. 400-8. Uses not permitted (of flexible cords and cables), and Art. 410-47. Screw shell-type lampholders.
It looks as though there are at least four different cords connected to this one fixture, possibly two of which have had it's ground circumvented by all this.
Joe; wonder what the "cord" is which enters the picture from the left (with the wire nuts). It almost looks like a piece of romex
with a short piece of lamp cord/plug spliced to it.
I know that lampholders such as this are made (were made) with an auxilliary outlet off to one side. This is really stretching it. [Linked Image]
[This message has been edited by mamills (edited 09-05-2002).]
Yeah, that sure looks like a piece of #18 gauge lamp cord spliced to the romex and plugged into a triple cube tap that goes to the receptacle on the porcelain lamp fixture. Then there's another cord with a black round plug connected to that that thing (towards the top).
Porcelain ceiling lamp fixtures like that are still made with either grounding and non-grounding receptacles on the side. The pull-chain switch only controls the lamp and the receptacle stays on.
I'm sure, however, that the manufacturers never intended them to be used like THIS!!
Also, look at how the lamp cord connected from the screw-shell adapter is wrapped a few times around the ceiling and then goes to the little rubber connector that has the ground-cheater adapter and the black three prong cord hooked to it. Gotta give the genius responsible some credit here, at least he thought about providing some strain relief! Hahahaha! :-D
Where do all these wires go to anyway???
[This message has been edited by SvenNYC (edited 09-05-2002).]
Tools for Electricians
2023 NEC Now Available!
2020 Master Electrician Exam Preparation Combos
2020 NEC Electrician
Exam Prep Combos:
Master / Journeyman
Alan Belson
Alan Belson
Mayenne N. France
Trumpy 9
NORCAL 5
300,393 Are you busy
230,033 Re: Forum
214,833 Need opinion
